Stuart 263 Posted Tuesday at 20:15 Share Posted Tuesday at 20:15 Guys I have a 1.8 Zetec Silvertop with an MT75 gearbox in my Westy. I've been looking to source a spare concentric clutch slave cylinder. Nothing wrong with existing just for future proofing. Originally from the Ford Scorpio Mk 2 petrol and seemingly unobtainable. The diesel variant is available everywhere but the inlet and bleed are the wrong configuration. Question is could I adapt the diesel one? Is it likely to have the same bore & throw and is there enough space in there to run a feed line inside the bell housing and make a remote bleed with kunifer pipe? Or would I be looking at a gearbox change if the slave was to fail? (I think the cable clutch is a different box or perhaps bell housing?) Any experts out there? Quote Link to post Share on other sites
Trevturtle 912 Posted Tuesday at 20:27 Share Posted Tuesday at 20:27 If I remember correctly the slave cylinder also has a steel spacer glued to the standard slave cylinder So you need to add that to any replacement. I know slave cylinders are hard to find but I'm sure an aftermarket one was found. I'll see if I can find a link Quote Link to post Share on other sites
1960dave 256 Posted Tuesday at 20:44 Share Posted Tuesday at 20:44 I am going to take my engine and box out in a couple of days so I can get the part number off it if that helps. Quote Link to post Share on other sites
Stuart 263 Posted Tuesday at 20:50 Author Share Posted Tuesday at 20:50 Thanks guys. I have part numbers already Dave Quote Link to post Share on other sites
Mole 331 Posted 11 hours ago Share Posted 11 hours ago Have you tried retro ford? Quote Link to post Share on other sites
mowerracer74 0 Posted 9 hours ago Share Posted 9 hours ago Hi, Not an expert but, I have a 65 HA viva with a black top zetec and an MT75 gearbox. I converted it to run an external slave cylinder from wilwood. If i remember i will get a photo for you when i'm up the shed on friday. Quote Link to post Share on other sites
Stuart 263 Posted 9 hours ago Author Share Posted 9 hours ago @Mole I emailed them today but thanks. @mowerracer74 that would be great ta. Was it an internal slave before you converted it? My second car was a 67 HA Viva. Cost me £25 and I did 30000 miles in it! Quote Link to post Share on other sites
Mole 331 Posted 9 hours ago Share Posted 9 hours ago I may have a used one in the workshop..I will have a look.. Quote Link to post Share on other sites
Stuart 263 Posted 8 hours ago Author Share Posted 8 hours ago 6 minutes ago, Mole said: I may have a used one in the workshop..I will have a look.. Fingers crossed. Be fab if you have Quote Link to post Share on other sites
