Damp gearstick gaiter
Dean Goodall
Steve (sdh2903)
Yes. It's slightly different but close enough. You just need to use a bit of foam in places to fit.
This is the one I used
https://www.ebay.co.uk/itm/Austin-Mini-Rover-Mini-HEATER-RADIATOR-Matrix-1984-1992-/171250702784?_trksid=p2349624.m46890.l49292
But there is an all metal upgrade version aswell.
https://www.ebay.co.uk/itm/Rover-Mini-1984-1992-heater-matrix-Fairway-Driver-Taxi-ALL-METAL-NOT-PLASTIC-/293247431432?_trksid=p2349624.m46890.l49292
Link to post
Dean Goodall
removed the dashboard, found drips on bottom corners of the heater assembly box.  Hose connections were dry.  Dampness on carpet underneath and smells like coolant so concluded that the heater matrix is leaking! 😡
Could it be where the plastic mouldings are bonded to the metal core?
anyways, ordering the all metal heater matrix as suggested, thanks.  Begun removing the heater assembly, reckon I will have to dis-assemble and re-assemble in situ.
Link to post
jonjh1964
The all metal matrix is slightly bigger than the original, I made a bracket to hold it in place.  Fitted 5 years ago after the original failed at the O ring/coupling; no significant leak but a need to top up the coolant about once a month.
Link to post
Terry Everall - WSCC Competition Secretary
LOOKS LIKE YOU HAVE SOLVED IT
Link to post
Dean Goodall
Great pic, thanks. Good info.
Link to post
Rush Motorsport
Glad you found it before I had to suggest a horny other half.
Link to post
