ARB trailing rather than leading?
Thinking out loud here.
could you fit a regular front anti roll bar to the rear (trailing) of the wishbones rather than the front (leading)?
I dont think I have space for one at the front due to the rad fan
ive plenty space to the rear though
Link to post
Rhett - Joint Black Country AO
My Playskool version is rear mounted, no issues fitting, similar clearance issues and as it's an FW it was much easier to adjust the body work aswell.
Link to post
Thanks Rhett, that’s good to know.
It’ll be a playskool one I’ll get probably
did you get the sort or standard stiffness?
Link to post
Terry Everall - WSCC Competition Secretary
Talk to Luke at Playskool about matching bar stiffnesses to car weight (engine weight) etc
Link to post
Is this bracket alloy or steel?
I've got the factory steel top mounts welded to my chassis (2015 S2000)-I've moved my rad fwd to clear the roll bar
Though you've got more hanging off the front than me. Any reason your solid mounting it, rather than rubber bushes (GBS solid mount too)?
Link to post
Will do terry thanks. I know it’s a black art getting it all set correctly 👍
thanks Ian.
those brackets are the older folded aluminium ones (rubbish design which I’ve had to reinforce)
I don’t really see the need to mount rads on bobbins,  I’ve had a few different kits with different set ups (inc high vibrating Bike engines) and I’ve always solid mounted them with no issues.
when it’s solid mounted I can accurately position the rad and ducting inside the nose cone where as on bobbins it’s can bounce around
i don’t have enough space to move the rad forward due to the intercooler and ducting unfortunately.
mounting a bar behind the wishbone would be ideal
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
Unfortunately there's a lot of history of the welded alloy rads failing on solid mounts, in Caterham circles too. Obviously, a high failure rate doesn't mean they all will, many will be lucky. It's expensive when the luck runs out though. If it's wobbling around too much, then the bobbins are probably too soft, higher shear strength grades are available.
Link to post
That's a fair point Dave, so is the thought that vibration/harmonics  cracks welds or the force of weight the rad moving around un-dampened put too much stress though them?
I could maybe squeeze a very shallow, but wide bobbin in there. My other issue is those crap alu upper brackets, if theyre subject to much movement they'll just fatigue and fail.  some steel welded ones are now on my list
Link to post
I have a fairly high power, (ie bulky and heavy) fan, plus the 75mm rad, with ducting, so it's a fair weight - it cracked two or three sets of aluminium top brackets in short order - fatigued very quickly, one set lasted only weeks. I made my own steel mounts in the end, which have done four years and six or seven thousand miles, with no issues at all.
Link to post
Rush Motorsport
I don’t have bobbins either and mine has been fine, it’s a different rad style though. 347AE64A-021D-4233-8549-3A5BDD680632.thumb.jpeg.9239c449a6ccf4d26f804da22b5aea1e.jpeg
Link to post
Not the best of pics, but all I could quickly find for the top mounts; I had to quickly knock something up with an impending thousand mile plus trip to France.
Had to be quickly put together with what I had to hand, so sections of 4mm angle steel, welded together, with a 4mm closing plate on one end, and the rad bolts through that. (The chassis end picks up on the old aluminium bracket mount.)
Link to post
4 minutes ago, DMc said:
nice setup you've got there @Dave Eastwood (Gadgetman) - Club Secretary 👍
His pie warmer no longer get's warm 😄
Back to your topic. I've killed circa 5 rads without a real root cause been identified, hence I'd be scared to death to solid mount mine!
I agree you need to beef up the top mounts, as with the weight of rad, intercooler, water and pipework, it's a lot to hang on Ali.
Link to post
Is that what the cylinder is? 😄😄
Right guys, you've put the ****s up me now, I'm on the case....
Link to post
I lost a Radtech 55mm core job before I went isolation mount.
Link to post
