Steve20 20 Posted October 17, 2020 Share Posted October 17, 2020 Quick question, how wide is wide track please Thanks Steve Quote Link to post Share on other sites
Chris King - Webmaster 4,694 Posted October 18, 2020 Share Posted October 18, 2020 I think it might be in the faq section. I think it’s 50mm more than std - but you have an SDV which is not “std” Quote Link to post Share on other sites
Gary Taylor - Scotland AO 1,986 Posted October 18, 2020 Share Posted October 18, 2020 If you measure your front wishbone from bush Center line to upright ball joint then compare that to the Westfield wide track wishbone measured the same way ( can get that in a few minutes) you’ll know if it’s worth it. Edit Westfield wide track wishbone 385 mm from bush cl to upright ball joint Quote Link to post Share on other sites
Chris King - Webmaster 4,694 Posted October 18, 2020 Share Posted October 18, 2020 1 minute ago, Gary Taylor - Scotland AO said: If you measure your front wishbone from bush Center line to upright ball joint then compare that to the Westfield wide track wishbone measured the same way ( can get that in a few minutes) you’ll know if it’s worth it. Steve has Sierra SDV setup - so it's different... Quote Link to post Share on other sites
Gary Taylor - Scotland AO 1,986 Posted October 18, 2020 Share Posted October 18, 2020 2 minutes ago, Chris King - Webmaster said: Steve has Sierra SDV setup - so it's different... Yep that’s why if he measures his and compares to a wide track one he’ll find the difference the Mazda sdv ones are different again Quote Link to post Share on other sites
Chris King - Webmaster 4,694 Posted October 18, 2020 Share Posted October 18, 2020 On the Sierra SDV the top wishbone is the same as the std track, but the bottom is (from memory) 30mm wider. I think WF widetrack is 50mm wider top and bottom compared to std. Can't recall though if this is each side or in total! But I do know that going from Sierra SDV to WF widetrack gives you more steering lock and is easier to set up the camber 😁 1 Quote Link to post Share on other sites
