AIM remote buttons interface (RBI)
BugMan
Some advice hopefully from the collective here on the fitting of the buttons.
I have some 8mm push buttons on order from China, which have still not arrived yet, to be fitted into the fantastic 3D dash mount from the 3D group here.
This got me thinking if just normal single pole, single throw SP/ST for normal switch function Is what I need, or do I need to consider “Latching” switches?
Common scene tells me single pole, single throw switch with individual wiring for the indicator part of the switch???
:westy:
BugMan
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
Do you mean the AiM remote button interface used with the dashes where the built in buttons are inaccessible? If so, they need to be momentary, not latching types.
Link to post
Tim (TimDave25) - Joint Thames Valley AO
I agree with Dave. Like for like replacement of what's on the dash.
Link to post
Chris King - Webmaster
Definitely momentary. I have this set up.
Link to post
gee_fin
The Aim buttons I used (from Aim) had the wires terminated in a box, before outputting them to a binder connector. Not sure if the box is doing some compatible trickery or if straight plain buttons would work...
Link to post
That’s the “remote button interface” with a binder connector
Link to post
BugMan
Yep, thanks team, turns out the place we ordered from had cancelled the order for some reason, but I had guessed correctly momentary contact
Dave - yes the remote button interface is what I was talking about, all part of sinking my AIM into the dash
:westy:
Link to post
In which case, as in my other post, pretty much any 12 volt compatible momentarynswitch will do, just pick a style you like/works well!
Getting five buttons rather than four, will mean that in addition to the four menu/settings buttons, you can also have a discrete odometer reset button, very handy!
The interface box, is essentially turning the contact closure inputs into a can bus signal that the dash can understand.
Link to post
One note though, from memory, if your using one of the Can Channel expansion modules, to add more analogue/digital input channels, I seem to recall needing the Can Data hub, to give you more Can inputs, so that the RBI can be added on the same overall Can stream.
Link to post
The sole reason I bought it!
Link to post
Yup that’s what I needed as I’ve recently added a GPS08 - which is brilliant.
Link to post
Ive been curious about those, but is it more of a track day benefit?
Link to post
Yes - it's for track days really.
Link to post
