Steve’s FW 2.0 Zetec build – January 2021
SteveB21
 Share
On 04/06/2021 at 19:40, SteveB21 said:
Productive afternoon building the dash. Not got to the dash mounting holes yet Ben as I don't have a scuttle yet. Fitted the speedo function button bottom right of the speedo an fitted the heated windscreen waning light next to the heated windscreen button. Drilled these holes by slowly drilling a 2mm pilot hole to avoid pulling the foam, cutting the foam and vinyl around the pilot hole and then using a step drill to make the hole for the function button and a 1/2" sheet metal punch for the warning light.
The 3 small gauges were a  very tight fit and I had to remove the stickers that say "removal cancels warranty"!  I was very glad I got all 3 gauges straight first time.
Had to slit the vinyl corners to fit all the rocker switches, but the cuts are covered by the switch bezels.
The large gauges were a much easier fit.
Better give the kitchen table back now!
Steve, double check you have the extra parts of the loom that plug into your speedo and Rev counter then connect into the main loom. I discovered I was missing the Rev counter one today.
Link to comment
Thanks @Benrobson2999 I've got both connector looms. I guess you've realised they both need male spade connectors to join the main loom - these don't come with the kit, but Dan was kind enough to give me a handful when I was up there last week collecting the bodywork.
Link to comment
yes it’s a bit of a pain. Hopefully they can get one soon
Link to comment
Made a start on dry fitting coolant pipes and hoses, using rivnuts and machine screws to attach the P-clips in case I ever need to remove the pipes in future.  Only slight issue is the pipe on the scuttle just touches one of the fuse boxes, so I'll need trim the fuse box foot to ensure no contact.
Link to comment
Finished dry fitting the coolant pipes and hoses. First I trimmed the fuse box foot to clear the pipe on the scuttle:
I'm a little nervous that I don't have enough clearance for the hose around the steering rack as I was focussing on ensuring I had clearance at the brake hose, but I guess I will only find out when I put the car on to its wheels.
Fitted the large bore P clips with M6 hex bolts and rivnuts. Decided to use an additional spacer on the rear diagonal P clip to ensure clearance to the small bore pipe and hose.
Single spacer plus a washer used at the front:
Had to drill out my first rivet where a cable tie clip clashed with a hose. Drilled the hole out to 7mm to fit a blanking plug. Sprayed some cavity wax into the chassis to hopefully trap the rivet end and stop it rattling.
Finally, drilled a drain hole in the engine mounting bracket:
  • Like 5
Link to comment
Steve if you haven’t already. Save you some hassle when you get to this point. Check your relays/wiring on the ECU tray for the fan and indicators. See my latest dairy entry.👍🏼
Link to comment
Thanks Ben - I remember Mike's relay saga and I'm following yours with interest, so will definitely check my relays and their connector blocks. Spent the afternoon bleeding brakes and tightening up connections. Currently got a nice solid brake pedal and left block of wood holding the brake pedal down overnight.  Will inspect in the morning.
If (touch wood) the brakes are all good I will put the wheels on and drop the chassis so I can check the front coolant hose clearance to the steering rack. If that's all good I plan to connect the coolant system, wire up the dash, check the electrics and check the engine fires up before I rivet the scuttle panel in place and start the bodywork.
  • Like 4
Link to comment
Another milestone - dropped the chassis onto its wheels today. The brakes were still good this morning, with just some tiny weeps where the flexible hoses connect to the calipers, so tightened those up a bit more.
Put the wheels on and jacked the chassis down. My concerns about the front lower coolant hose touching the steering rack were unfounded. I definitely have some suspension adjustments to do!
Before:
After:
Coolant hose clearance:
  • Like 6
Link to comment
Took 5 minutes today to check my fan & indicator wiring - all OK and correctly wired in. IMG_5921.thumb.JPG.d446cf862264a36b057b02483e61a710.JPG
I also checked the LED relay had the same connection layout (it does) and fitted it in the relay block.
  • Like 4
Link to comment
Spent this afternoon fitting connectors to the speedo and tacho wires. Decided not to use the insulated connectors I picked up at Westfield, but spend some time fitting non-insulated crimp connectors and heatshrink sleeving. Thanks to @MikeJG for the useful wiring guide:
All ready to go:
Plus, a new tool arrived:
  • Like 3
Link to comment
Much nicer than the blue ones! I only use the insulated clear nice ones these day too.
Link to comment
  • 3 weeks later...
Not much to report recently as I had a few days off cycling, during which I took a heavy fall and badly bruised my ribs, which has restricted my garage activity. Finally got back to to work on the car today and made a start with some light electrical work on the rear lights. Tested they all worked first and then fitted the 2 pole Econoseal connectors to the fog & reversing lights, having first checked they would reach the loom connectors. Having an Econoseal crimping tool is definitely worth it!
Fitted the lights into the rear body and it's obvious they will need some adjustment to get them aligned horizontally, but will leave that until I have the body fitted.
The manual talks about gluing the indicator and rear/stop lights in place, but I think I'll fit them with self-tappers, as per the reflectors.
Link to comment
Minor milestone - first holes drilled in the bodywork!  Reflectors fitted and holes drilled for number plate light, having made multiple measurements to ensure it was central. Will get some M3 machine screws to fit the light, rather than use the self-tappers supplied.
Used a cone drill to open out the hole for the number plate light wires, having drilled a 4mm pilot hole first.
Link to comment
 Share
