The_big_1 0 Posted October 10, 2020 Share Posted October 10, 2020 Hi all, In the middle of a build, not a Westfield but very similar. So lucking to use the Westfield intake on my Zetec Blacktop engine using the original inley manifold. The original Zetec is a sort of joint pipe with the MAF fitted. On the Westfield instalation, which MAF is fitted and where? Many thanks!!!! Quote Link to post Share on other sites
Michael Whitworth 170 Posted October 10, 2020 Share Posted October 10, 2020 Do any Westfields actually run a MAF sensor? As most that I have seen have custom management systems. They rely mainly on TPS for load but some might also utilise a map sensor too. This is not authoritative as I am not familiar with modern Westfields. lol Quote Link to post Share on other sites
The_big_1 0 Posted October 10, 2020 Author Share Posted October 10, 2020 Lol yeah I guess that could be possible. Just seeing whats out there. Most injection systems need a MAF so the inlet air temp is known etc. Engine runs different if its say 5 degrees air temp or 25 degrees, be interested to know how the Westfield would deal with this without a MAF Quote Link to post Share on other sites
Michael Whitworth 170 Posted October 10, 2020 Share Posted October 10, 2020 Separate intake air temp sensor or TMAP Quote Link to post Share on other sites
The_big_1 0 Posted October 10, 2020 Author Share Posted October 10, 2020 Hi ya, do you know which one or where its mounted, I guess in the intake pipe? I guess if running standard Ford setup, I could fit an original MAF in the same place? Quote Link to post Share on other sites
Michael Whitworth 170 Posted October 10, 2020 Share Posted October 10, 2020 I have no idea as both my Westfields are on Redtops with ITBs. The IATS is mounted on the Air filter back plate. And is a common 2 pin Bosch type. Quote Link to post Share on other sites
Dave Eastwood (Gadgetman) - Club Secretary 7,323 Posted October 17, 2020 Share Posted October 17, 2020 Most modern Westfields use aftermarket ecu’s, not the original car manufactures system. Very, very few of the type of aftermarket ECU used in Westfields are even compatible with MAF sensors, so the topic just doesn’t come up. As a result, most use a very basic, but very effective setup, of TPS, (throttle position sensor) air temp sensor, water temp sensor, and apart from a Lambda sensor, that’s frequently it. (There are exceptions, we have kits called single donor vehicles, built around as much as possible of a Mazda MX5, which use the Mazda ECU and I think MAF sensor) Quote Link to post Share on other sites
Chris King - Webmaster 4,694 Posted October 18, 2020 Share Posted October 18, 2020 I think some folk on Locostbuilders.co.uk use std ECU on some builds - might be more info there? Quote Link to post Share on other sites
Ian Kinder (Bagpuss) - Joint Peak District AO 4,841 Posted October 18, 2020 Share Posted October 18, 2020 On 10/10/2020 at 21:03, The_big_1 said: Lol yeah I guess that could be possible. Just seeing whats out there. Most injection systems need a MAF so the inlet air temp is known etc. Engine runs different if its say 5 degrees air temp or 25 degrees, be interested to know how the Westfield would deal with this without a MAF MAF = mass air flow. It's uses a heated wire in front on a sensor to detect the change in temperature, caused by the air flow and hence it's a good method to measure the air consumed by an engine. Some also feature inlet air temperature measurement too. Quote Link to post Share on other sites
Gary Taylor - Scotland AO 1,986 Posted October 18, 2020 Share Posted October 18, 2020 On the Mazda engined builds where I have used the std ecu the Mazda ecu needs to register a signal from the maf on start up if it doesn’t it cuts the fuel / ignition circuit after a predetermined time. ( resets after turning ignition off then on again) Doesn’t matter where it goes in the intake line . The supercharged version it was immediately after the filter before all the s/c gubbins on my white westy its immediately before the throttle body. On the new westy having Individual throttle bodies and using an me221 ecu , the ecu uses a manifold air pressure ( map) takeoff. As well as TPS AND AIT ( air intake temperature) sensor on each set up Sorry I cant comment on the ford setup , it may help aswell if you say which ecu you have ( sorry if I missed that earlier) good luck Quote Link to post Share on other sites
Ian Podmore 34 Posted October 19, 2020 Share Posted October 19, 2020 I have one mine, a Zetec 1800 from 1996. Running the Ford EEC IV ECU. The MAF sensor is at the entry of the inlet pipe to the throttle body. This is a standard Ford item that runs over the cam cover then above exhaust side to above thermostat housing. I changed the original airbox to a cone filter mounted directly to the MAF sensor. Quote Link to post Share on other sites
