Morris 315 Posted October 11, 2020 Author Share Posted October 11, 2020 20 minutes ago, Steve (sdh2903) said: @Ian Kinder (Bagpuss) - Joint Peak District AO currently we're using trescal. We also use Trescal at work - excellent service to date. Quote Link to post Share on other sites
Bandageman 21 Posted October 15, 2020 Share Posted October 15, 2020 I’ve recently bought a Westie and plan to do my own servicing etc. My 2 x torque wrenches (low and high reading) are both well over 30 years old but not sure if they’re still ok. What’s cost for calibrating them, and is there a trusted lab I could get them done. Just wondering if I’d be better/safer buying new based on posts. Based in Glasgow area. Quote Link to post Share on other sites
Ian Kinder (Bagpuss) - Joint Peak District AO 4,841 Posted October 15, 2020 Share Posted October 15, 2020 Here's how you can check the accuracy of your torque wrench, though I'd suggest using a bolt held in a vice rather than risking damaged to a tin top / alloy wheel: I'd also suggest checking at or around the value your using it for. E.g. Most are adjustable over a quite wide range and if you've adjusted it to be accurate at 200Nm it may be out at 20Nm. I always store mine with it set on min. Which is good practice. Quote Link to post Share on other sites
Barnsley John 475 Posted October 17, 2020 Share Posted October 17, 2020 On 15/10/2020 at 07:33, Ian Kinder (Bagpuss) - Joint Peak District AO said: Here's how you can check the accuracy of your torque wrench, though I'd suggest using a bolt held in a vice rather than risking damaged to a tin top / alloy wheel: I'd also suggest checking at or around the value your using it for. E.g. Most are adjustable over a quite wide range and if you've adjusted it to be accurate at 200Nm it may be out at 20Nm. I always store mine with it set on min. Which is good practice. I read as well to store your torque wrench with no tension 1 Quote Link to post Share on other sites
Bandageman 21 Posted October 17, 2020 Share Posted October 17, 2020 Local calibration station are quoting me £30 for my up to 30Nm torque wrench and £40 for torque wrench 40 - 70 Nm. Not sure if this is legit, but seems a bit like profiteering to me. surely calibration of a torque wrench is standard, or am I being naive? Quote Link to post Share on other sites
Morris 315 Posted October 18, 2020 Author Share Posted October 18, 2020 @BandagemanI've just bought one of these Sealey jobs that comes with a calibration certificate. Less than £40 and you can be sure it was accurate at least when it was calibrated...😀! https://www.ebay.co.uk/itm/133114108671 Quote Link to post Share on other sites
Bandageman 21 Posted October 18, 2020 Share Posted October 18, 2020 Hi Morris, thanks for that. I kinda thought that the calibration place I went to was taking the mickey. Or maybe they just deal with commercial premises who need to have their Teng/Snap-on torque wrenches calibrated and it’s worth it for them, as these things cost several hundred pounds. I’ll just order from eBay I think. Quote Link to post Share on other sites
Rush Motorsport 2,686 Posted October 18, 2020 Share Posted October 18, 2020 7 minutes ago, Morris said: @BandagemanI've just bought one of these Sealey jobs that comes with a calibration certificate. Less than £40 and you can be sure it was accurate at least when it was calibrated...😀! https://www.ebay.co.uk/itm/133114108671 £270 down to £38? Seems legit. Quote Link to post Share on other sites
Morris 315 Posted October 18, 2020 Author Share Posted October 18, 2020 Yes, that discount is somewhat unbelievable! Quote Link to post Share on other sites
Bandageman 21 Posted October 18, 2020 Share Posted October 18, 2020 👍 Just snapped one of these up. Let’s hope we’re all pleasantly surprised. 1 Quote Link to post Share on other sites
Burgerbob 71 Posted October 18, 2020 Share Posted October 18, 2020 Couple of quid cheaper at Amazon https://www.amazon.co.uk/Sealey-AK624B-Calibrated-Micrometer-Torque/dp/B06XS7TN14/ref=mp_s_a_1_1?dchild=1&keywords=AK624B&qid=1603043439&sr=8-1 Quote Link to post Share on other sites
Morris 315 Posted October 18, 2020 Author Share Posted October 18, 2020 34 minutes ago, Bandageman said: 👍 Just snapped one of these up. Let’s hope we’re all pleasantly surprised. Yes, hope so. It looks very much like my 30 year old Draper wrench but in black. Seems to be sold in many places at a similar price. Quote Link to post Share on other sites
Steve (sdh2903) 3,379 Posted October 18, 2020 Share Posted October 18, 2020 That's an absolute spitting image of my teng one I linked to at the start of the thread. I'd imagine all must be made by the same manufacturer with different branding. 1 Quote Link to post Share on other sites
