Lsd for my live axle
Ben(EBD-ENG)
Ben(EBD-ENG)
So project diff is a goer.
Talk to me about the difference between an atb and a plated. My car is track only. Not road legal so not bothered about road compliance
Link to post
  • Replies 40
  • Ben(EBD-ENG)
    16
  • Rush Motorspork
    6
  • Andrew
    5
  • AdamR
    4
Popular Posts
Evidence points to the contrary 🤣
Lol. If an open is more forgiving in the wet then. It must be the suspension. Obviously it can't be my driving skill. So it must be that
ATBs don’t require any maintenance. Plated diffs need the plates replacing eventually.    ATBs don’t work if you have a wheel in the air, so not great if you’re a kerb monster. Plated diffs
Rush Motorspork
ATBs don’t work if you have a wheel in the air, so not great if you’re a kerb monster. Plated diffs allow even madder skidz.
Easy to understand explanation here
https://www.carthrottle.com/post/whats-the-difference-between-geared-and-plated-limited-slip-differentials/
(I’ve got a plated diff)
Link to post
Ben(EBD-ENG)
Who fitted yours?
Link to post
Rush Motorspork
Luke, but only because the car was up there. I bet procomp would do it and a bit more local.
Link to post
Ben(EBD-ENG)
am i right in thinking that Timken bearings are the best for the live axle
Link to post
Andrew
I dont think I've ever had to change my live axle bearings because of bearing failure.. but I've had to swap a few because of the integral oil seal failing. The last one's I fitted were Timken, and so far so good.
Link to post
Ben(EBD-ENG)
i thought i might aswell change them all as im fitting a diff.
Link to post
Andrew
Tbh, if the bearings aren't worn / making a noise, and the seals aren't leaking, I'd be inclined to leave them be. It's not a big job to change them with the axle in situ if you have to at a later date.
Link to post
Ben(EBD-ENG)
the seal is no more by the looks of it
Link to post
Andrew
It is an ex seal. 🙂 Has it been leaking then? Btw, I'm talking about the seals built into the bearing.. not the bearing retainer plate things.. held on with four bolts?
Have you found the source of the knocking sound?
Link to post
Ben(EBD-ENG)
It hasn't been leaking it looks like it's been gummed up with sealant. I haven't found anything obvious other than there seems to be a lot of back and forth movement between the crown wheel and pinion. But I can't be sure of this yet as I haven't found the info telling me how much there should be.
Link to post
