Gary Taylor - Scotland AO 1,986 Posted September 29, 2020 Share Posted September 29, 2020 Evansandsonrallyspares.co.uk I've used these lads before They do axle rebuilds and can supply the parts ( axle and internals, radius arm brackets and pan hard bracket) also do a rear disc conversion. you would need to tell them the measurements off your own axle; length of axle between back plate flanges, distance between the radius arm bracket and distance from back plate flange to the pan hard bolt centre along with photos and I’m sure they could do the fabrication work , then you could sort out what you want on the internals and they will do the rebuild as well if required Chat with them and send pictures / descriptions of what is needed. Good luck Quote Link to post Share on other sites
Jari 6 Posted September 29, 2020 Author Share Posted September 29, 2020 5 minutes ago, Gary Taylor - Scotland AO said: Evansandsonrallyspares.co.uk I've used these lads before They do axle rebuilds and can supply the parts ( axle and internals, radius arm brackets and pan hard bracket) also do a rear disc conversion. you would need to tell them the measurements off your own axle; length of axle between back plate flanges, distance between the radius arm bracket and distance from back plate flange to the pan hard bolt centre along with photos and I’m sure they could do the fabrication work , then you could sort out what you want on the internals and they will do the rebuild as well if required Chat with them and send pictures / descriptions of what is needed. Good luck Thanks ! I will have a look. 1 Quote Link to post Share on other sites
Jari 6 Posted October 21, 2020 Author Share Posted October 21, 2020 On 29/09/2020 at 14:44, Jari said: Thanks ! I will have a look. On 29/09/2020 at 14:39, Gary Taylor - Scotland AO said: Evansandsonrallyspares.co.uk I've used these lads before They do axle rebuilds and can supply the parts ( axle and internals, radius arm brackets and pan hard bracket) also do a rear disc conversion. you would need to tell them the measurements off your own axle; length of axle between back plate flanges, distance between the radius arm bracket and distance from back plate flange to the pan hard bolt centre along with photos and I’m sure they could do the fabrication work , then you could sort out what you want on the internals and they will do the rebuild as well if required Chat with them and send pictures / descriptions of what is needed. Good luck I contacted these guys and they will make one for me. Now I just wonder if I should take disc brakes instead of drum but Im thinking of the balance. Will there be too much brake force in rear then ? A bias valve is not accepted for road cars in Finland. A LSD I will likely take as it is not that much more money than a conventional. Quote Link to post Share on other sites
Gary Taylor - Scotland AO 1,986 Posted October 21, 2020 Share Posted October 21, 2020 Hello Jari , I’m glad they can help you, for a road car then the drums will be fine and it saves you any complications with the authorities Quote Link to post Share on other sites
Jari 6 Posted October 21, 2020 Author Share Posted October 21, 2020 8 minutes ago, Gary Taylor - Scotland AO said: Hello Jari , I’m glad they can help you, for a road car then the drums will be fine and it saves you any complications with the authorities Thanks ! Drum brakes then. They use 9"- RS drums. Should be ok ? 1 Quote Link to post Share on other sites
Gary Taylor - Scotland AO 1,986 Posted October 21, 2020 Share Posted October 21, 2020 Yes that will be fine 👍 Quote Link to post Share on other sites
