Oil cooler piping
Paul Hale
Paul Hale
My Seight has an oil cooler fitted, but I note that one of the short feed pipes to it hangs very low at the front of the car-in fact, lower than the sump! I am keen to avoid seeing this pulled off on traffic calmers etc. and wonder if this is normal, or should I / can I reposition if, out of harm’s way?
Link to post
Doesn't sound good @Paul Hale some pics of it with the fitting at either end may help us to advise. It may simply by a case of adding a P clip to support it, or rerouting etc. May be the fittings at either end can be loosened to allow the hose to swivel and then tighten to re-secure with reduced sag etc.
Link to post
the stoat
Also double check if the cooler is needed.  If you are not doing track work it could be over cooling.
But as above I would want it out the way as the cooler pipe on a previous car let go and it is amazing how much oil is lost in a few seconds.
Link to post
