Zetec Blacktop - lightweight Flywheel options
Andrzej
Andrzej
Slowly starting to think of rebuilding some components in the winter.
One of the changes I want to make in  the car is the flywheel-clutch-clutch cover lightening.
Currently there is approx 10kg flywheel + 240mm helix paddle clutch + sachs sport clutch cover. Mt75 gearbox with cable operated clutch.
What options do You more experienced Westfield users recommend ? Car is for track only.
As I looked what are the options I can see :
1. Burton Power flywheel : 6,8kg - described as for "pinto" clutch - 220mm (or 215?)
2. Raceline Flywheel - 5,5-6kg
3. Retroford - 3,9kg (! but most expensive one)
4. Dunnel - approx 7kg but not sure if they sell it or I need to deliver my flywheel to Dunel first.
5- ? ? ? - any other options ?
I am not sure if all those flywheels have the same external diameter - for the starter to fit (anyway I need a new starter so no problem with choosing correct one I suppose).
Not being familiar with all those Ford-related names , I assume that "pinto"clutch means smaller - 220mm and that it can be fitted on the same gearbox shaft. I think if so, there is some Hellix available for this size.
Are there any disadvantages (except the price ) for the most lightweight one ? It seems that the Raceline is in the middle and seems to be most reasonable in the price/weight aspect, waiting for the answer from Raceline , but want to hear Your advices , opinions etc ?
Link to post
Another supplier option for you
https://www.rwdmotorsport.com/product/ford-zetec-e-lightweight-steel-flywheel/
They should be able (like others you have listed) advise on the best combination of flywheel, clutch, starter etc. As they can supply all these.
I have a number of parts from them and the quality looks good.  Not fitted yet so I can only go of appearance and customer experience so far.
Link to post
Kit Car Electronics
I can't remember the inertias, but on Silvertop at least, the standard 1.8l flywheel was much better than the 2.0l one as well, and interchangeable
Link to post
Rhett - Joint Black Country AO
another supplier I beleive that are used is TTV which look to supply some different options.
Link to post
Ben(EBD-ENG)
Dunnell also sell lightened flywheels just seen your post you already know dunnell supply them lol
Link to post
Andrzej
Wow, so much options!
First I should determine the weight I suppouse. So Wonder what weight of the flywheel is considered "OK" for the trackday use ?
dont wont to go to low, as I read there could be problems with gearchanges. But maybe if going for the dogbox, which I am going to - it will be beneficial (as low weight of the flywheel as possible?)
Other subject but connected to flywheel - looking at the clutches from some of above suppliers, I can see some of them are solid - no springs in clutch plate.
I had a trackday car with such "stiff" clutch and it failed due to lack of those springs at the most unfavorable moment !
As I talked later to some guys preparing cars for motorsport, they said, that there is a reason why Helix clutches have those springs. There should be some place for the vibrations and forces to spread, if not - something will broke. But that is other issue.
Now to the flywheel 4 or 5 or 6 kg - will be there a real difference in going RPM's up ? maybe most reasonable will be this 6kg (+) from Burtonpower + helix clutch and cover also from Burtonpower ?
Link to post
Chris King - Webmaster
Mine is 3.9kg (or less) and is fine for road and track. I just keep idle at 1000 revs or so instead of 800.
No direct comparison though as it’s been the same since I built the car!
Link to post
3 minutes ago, Ben(EBD-ENG) said:
is the std flywheel around 8.5kgs? or more?
Depends on engine. 1.8 silvertop is a lot lighter than the beast of a blacktop. Think the blacktop is well over 10.5kg but don’t quote me!
Link to post
Ben(EBD-ENG)
ive been pondering a lightweight flywheel for a winter upgrade. ill have to have a look at what ive already got
Link to post
AdamR
As long as there's enough for the clutch to bite against, and it doesn't explode, go nuts!
Link to post
yes think of the location and how much you like your tibia and fibula. 🤔
Link to post
... don’t want one like mine 🤣
  • Sad 1
Link to post
