VDO Speedo Setting
Hornet600
Hornet600
Hi all
Does anyone know the calibration impulse value i should set the speedo at.. 15" wheels with sensor on front reading from a bolt?
Link to post
Rich201060
Speedo pulses .rtf
Not sure where I had this from mine ended up as the example 3595, assuming the sensor is triggered 4 times per rev.
Edit: Ah VDO may be different ?? I will get my coat😀
Link to post
  • 2 weeks later...
Hornet600
Hi Quinten  that worked brilliantly.. thank you.
I have entered the figure and test driven the car... looks like the speedo is running 5mph over the sat nav reading. Does that sound about right to everyone or should i alter the figure from the programme to make it more accurate?
Link to post
Quinten
I'd leave it at that if that's at 70mph.  That way you're never going to be caught out by keeping to the speed limit on the gauge.
Link to post
