Westfield XI Panhard Rod onto live axle SEW?
Dan_G
 Share
Question(s):
Has anyone tried fitting a Westfield XI Panhard rod onto a live axle SE / SEW?
Can any Westfield XI owners measure the panhard rod and rose joint adjust ability?
I am looking to add lateral adjustability to my live axle setup to fine tune the axle position and was wondering if the XI panhard rod / rose joint arrangement would do the job.
My current Panhard rod is 1000mm between bush centres.
Thanks in advance.
Dan
Link to comment
I wouldn’t have thought they’re the same dimensions as the X1 is designed to use a.n MG midget axle rather than escort.
its probably just as easy to modify your existing panhard Rod, all you need is to cut one end off the rod and then weld in a threaded insert such as these.
http://www.mcgillmotorsport.com/rod-end-accessories-imperial-sizes-weld-in-threaded-bungs-tube-adaptors/
Link to comment
Cheers for that...
Definitely easier buying a panhard rod for £24 direct from Westfield than me spending the time... path of least resistance and all that... 🤣
But I will if i need to... 👍
Link to comment
 Share
