Lowered Floors - Bottoming Out
LythamBrownie
 Share
4 hours ago, Chris King - Webmaster and Joint North East AO said:
I still have my 1994 Marin Pine Mountain - it‚Äôs in bits as the BB is seized in. Been like that for maybe 20 years ūüôĄ
My first MTB was a Marin Eldridge:
Then I went to a Trek 8000 hard tail, upgraded with Manitou shocks,
and shortly after that to current MTB - the 1st Marin Mount Vision full sus model which was upgraded under warranty to an updated rear box section swing arm.
Link to comment
On 11/08/2020 at 14:07, AdamR said:
You can't see the lock nuts on that photo - they are covered up by the black rubber bump stops. Once the locknuts are undone, the top eye (the one without the damping adjuster) screws off.
@AdamR..... can I just ask.....?!?!?..... does the spring need to be compressed to undertake this job?
Link to comment
No, completely slack. Unscrew the preload collar a few turns so the spring is slack, then you will have access to the top eye and locknut.
Link to comment
  • 2 weeks later...
I hope the OP doesn't mind but can I get some more advice on fitting new bumpstops?
@AdamR
 I bought some of the bumpstops you linked to. I have approximately 70mm travel left on the front shocks at the correct ride height. Any advice on how much to trim the bumpstops?
Do I want them to only contact right at the end of the travel (like the stock ones) or earlier?
if earlier, any suggestions as to how much travel before contact?
Link to comment
Earlier. Every car is different with respect to how much to cut off.
Set dampers to minimum, put a ~15mm bit of wood under the sump (front) / lowest point of the car (rear), remove the springs (or slacken collars right off), then jump with all your weight on the car (stand on the cage / chassis). Keep cutting a few mil off the bump stops until the car JUST contacts the wood. Repeat process for both ends individually. Reinstall springs, and it will never bottom out now.
You may end up with not a lot of damper shaft showing, that's fine.
Link to comment
Excellent Adam, many thanks :yes:
Link to comment
 Share
√ó
√ó
