aeg
Zetec crankshaft oil seal front
aeg
Hi, anyone out there changed the front crankshaft oil seal on a Zetec recently? Trying to sort my oil leak out and I think it’s coming from the front pulley area so it’s fact finding time before it’s pull it apart time!! Cheers Andy
Share this post
Link to post
RussH
I’ve just done it on an MX5....be very careful you don’t scratch the crank when you remove the seal!
Share this post
Link to post
Ben(EBD-ENG)
screw two self tapping screws into the seal and pull it out is the way ive always done them
Share this post
Link to post
Ian Podmore
And this is how I put a scratch in my crank. Luckily I was able to clean it up (sighed with relief).
I have changed it a few times on my Zetec as I couldn't stop it leaking, I had been using standard Ford ones, the last time used one from Burton.  It's never leaked since.  Price was about 30% of Ford one as well, and much easier to fit.
Share this post
Link to post
aeg
Thanks for the advice guys, something to look forward to when I come back from my hols 🙄 cheers Andy
Share this post
Link to post
aeg
Well after Thursday nights area meeting the consensus was its the front crankshaft seal so tonight i started the strip down to change it !!
Now I've got in to have a good look at it I'm unsure?
Here's the photo , i was expecting to see a lot of oil behind the pulley and cover when i took it off, I'm back to thinking could it be the sump gasket leaking at the front and it catching the pulley and spraying it everywhere?
Thoughts guys !!
Share this post
Link to post
corsechris
Doesn’t look like it’s coming from the crank seal to me.
Share this post
Link to post
Dylan
Had exactly the same problem,changed the oil seal twice still leaked.Turned out to be the oil pump gasket had blown at the top letting oil leak down onto the oil seal.Bigger job than anticipated sump off oil pump off new gasket but cured oil leak.
Share this post
Link to post
the stoat
For us XE owners that is not a leak, that is mild weeping.....
Share this post
Link to post
