LukeW
S2000 cooling problems.
LukeW
I will check this return line tomorrow now. Don’t recall seeing any restrictor in place but it is a smallish bore hose on the return from rad. 🤔
Share this post
Link to post
CraigHew
1 hour ago, LukeW said:
Have you got a video of this,
i noticed it was dribbling back to expansion tank on idle but that was with thermostat removed!
Not to hand, but I'll post you one tomorrow morning when I'm home.
Share this post
Link to post
It's not standard fitment. I put one with a 2mm hole in mine. I put a cable tie on the hose where the restrictor was, to aid locating in the future. I fitted it to limit how much water was bypassing the block. Just leaving a small hole should allow any air to leave the top of the rad.
Share this post
Link to post
the stoat
Just a thought given the car is OK running.  Is the fan wired up backwards and so not being very efficient?
Share this post
Link to post
CraigHew
Here you go
Share this post
Link to post
Scotty72
5 minutes ago, CraigHew said:
Here you go
This looks about the same flow as my car at idle.
I have replaced the coolant twice during ownership and when refilling poured new coolant in slowly with bleed valve on top of block open to aid release of air.
Had no issues with airlocks.
Share this post
Link to post
LukeW
6 hours ago, CraigHew said:
Here you go
Mine is nothing like this on idle even with thermostat back in!
dribble on idle with positive flow when holding throttle on slightly.
just doing first warmup after filling with only water for now and it’s the yellow area of the rad that get warm first
should it not be the blue area given this Ian the feed from the thermostat?
Share this post
Link to post
LukeW
Fan is correct way as it pulls a piece of paper to the front of the rad when it’s running
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
No, the rad should get warm from the top.
Coolant enters the rad at the top, from the water elbow at the back of the inlet manifold. It then travels across the top half of the radiator, to the off-side of the car, before dropping down inside the rad and traveling back across the lower half. It then exits the bottom of the rad, where it's drawn back towards the pump.
The thermostat opens and closes the return feed to the pump from the rad, on an S2000.
In an ideal world, you don't actually want that much flow from the radiators  upper self bleed connection, back to the header tank, as this is coolant that's not passing through the rad. Hence reducers in the line are sometimes used by builders.
However, you wouldn't expect the flow pattern through the self bleed hose to suddenly change for no reason...
Share this post
Link to post
LukeW
Thanks @Dave Eastwood (Gadgetman) - Club Secretary
The flow through bleed hose back to header tank changes when the throttle is opened slightly so the pump is working harder.
I had a thought that maybe belt is slack and slipping but then my alternator wouldn’t necessary be charging the battery?
So my dash displays 98 degrees then fan kicks in and cools straight town to 96 on the dash.
The fan thermostat is 98-93 as I’d pulled that out yesterday, is this potential cause for concern?
it was also notice the level in header tank reaches around half then when the fan kicks in and cools it this level drops to below a quarter!
Is this normal?
level before fan kicks in
level as fan goes off?
Share this post
Link to post
LukeW
Also tried to connect to ecu to compare temp readings. But mines locked
dont suppose anyone has a .GIN
file for the locked omex 630
630 01M31r1
Share this post
Link to post
Steve (sdh2903)
The level will rise and fall more with the cap off as its a pressurised system. Try it with the cap on.
Share this post
Link to post
Steve (sdh2903)
In fact I wonder if your issues are down to a knackered expansion tank cap, if the system  isn't pressurising properly can cause weird issues including overheating.
Share this post
Link to post
Test the cap with a foot pump plumbed in. It makes a honk as it opens at circa 22psi from memory. I cut a schrader valve of an inner tube and fastened into a hose with a jubilee clip. Then used a 8mm t piece to plumb it in.
Share this post
Link to post
LukeW
Now you mention it
one time whilst I was away and temp showed high I pulled over and did slowly remove cap from expansion tank much to my surprise it didn’t take long to equal atmosphere and the level didn’t rise to the top of the tank as I would expect!
Share this post
Link to post
