Matt_S
Bonnet Shut Lines
Matt_S
Hi all,
How important are the shut lines for the IVA?
Ive been playing with the fit of my bonnet for quite a few hours now but cannot improve the fit. It’s mostly the front left hand side between the nose cone and the bonnet, the bonnet protrudes from the side around 2-3mm.
The gap between the back of the nose cone and the front of the bonnet is fairly even but still the gap is around 4-5mm. I’m not to worried about this as I can add some foam to fill in the gap.
I have also measured the length of the bonnet each side of which there seems to be about a 10mm difference. I take it this is normal as well.
Just need a general consensus really, should I be worried or not for the IVA?
Share this post
Link to post
Si.Dalziel
The bonnet spends most of the IVA on the floor!
This is mine working it’s way down the line.
getting it looking like a well built machine is half the battle for IVA but you can only do so much with the bodywork. Mine has a step of about 5mm on one side where the bonnet seems slightly wider than the scuttle. You have to be pretty picky to notice it though.
Share this post
Link to post
Matt_S
Well if that’s the case I’m not going to spend anymore time on it.
Like you say the bonnet is definitely wider than the nose cone so not a lot can be done.
Share this post
Link to post
John Dolan - Chairman
The grommet is for the locating pin fixed to the bonnet. Available from the factory, easy fit.
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
That reminds me, I need some spare bonnet grommets, seem to have used all mine!
Share this post
Link to post
Matt_S
Yes I fitted my bonnet pins a few days ago I just couldn’t get the shut lines any better.
Share this post
Link to post
Andy M
Think I need to order some of these for mine. Cheers.
Share this post
Link to post
Clamp the bonnet and nosecone together, then drill the holes for the locating pins.
Share this post
Link to post
Ordered! thanks for reminding me, usually only remember I need one when checking under the bonnet before going for a run, then promptly forget!!
Share this post
Link to post
