Barnsley John
Fuel pressure regulator S2000 - location
Barnsley John
 curiosity
  were is it
Is it built in near fuel rail
And with no gauge just a enclosed unit by honda
Thanks john
Share this post
Link to post
6 minutes ago, Barnsley John said:
 curiosity
...killed the cat........don't maintain your poor Honda to death 😉
  were is it
It's on your fuel rail.
Though it shouldn't have the vacuum hose connected to the manifold as shown here.
Are you still having problems ?
Thanks john
Share this post
Link to post
Si.Dalziel
9 minutes ago, Barnsley John said:
 curiosity
  were is it
Thanks john
it’s on the fuel rail I’m sure it’s the bit with the plastic hat/cover. It should have a vacuum pipe off it which isn’t connected anymore. Or it’s the other bit on the fuel rail without the hat. Either way it’s on the fuel rail and should have no hose on it.
Share this post
Link to post
Barnsley John
I have not driven scince i fitted
new fuel filter  2 days ago and decided to finish job off by also cleening icv valve
  waiting for 5 star torx spanner to do icv
Car seems ok in garage  but needs a run
I was reading about someone s fuel pressure guage and  thought were is mine
Its just education no not messing with anything like that
Hoping that the fuel filter that was wrong way was the problem and maybe some crap fuel that s causing issue
Car in genral as run brill thanks for you repyls john
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
Fuel pressure gauges should only be used temporarily connected up, either whilst setting the pressure on a variable regulator, or to test that a fixed type is the right one/operating properly. I know some do, but it can be risky in a petrol spraying round the engine compartment sort of way, if one should fail while connected in as you drive round. (They’re not normally designed for that sort of rough service.)
Share this post
Link to post
Barnsley John
Verry good reply and good advice dave
I take it then the ones on our s2000 cars are a preset  unit from the factory and have been calibrated for the standard honda engine setup
Thankyou john
Share this post
Link to post
If you have the original Honda throttle body, then the Omex system has been mapped for the Honda pressure regulator, and you don't need to touch it, it's not adjustable.
If you have the sepperate throttle bodies, then the Omex ones came with a new pressure regulator, that matched the map, and again, its fixed, so no adjustment necessary.
Share this post
Link to post
Barnsley John
Thankyou
Share this post
Link to post
LukeW
Careful with this @Barnsley John this is one of the jobs I did just before overheating issues 😞 not saying this was/is the cause though!
Seemed a straight forward job when I was doing it!
Share this post
Link to post
Barnsley John
Will take that,onbord
I havent started it yet as the 5 spoke tool aint come
Also took car out this morning ang tried the new fuel filter out the right way round nay i say scince finding it wrong way
Gave the car a good thrashing this morning it seems perfect so may put that job on hold now as the cause may have been dirty fuel and filter
Share this post
Link to post
