Sign in to follow this
Rednop1
250 gearbox
Rednop1
Mazda mx5 gearbox
As fitting to the sport 250
This has done 10 miles from new before removed
Yes 10 miles !!!!!
These are £2500 from westfield
£900 collection only or send your man with a van i will not put on a pallet and send
Share this post
Link to post
Rednop1
All pm's replied too
Forgot too mention comes with the westfield shaped gearstick and sleeve which are £140ish from westfield
Share this post
Link to post
Steve (sdh2903)
And the concentric slave conversion too which is well over a hundred quid on its own.
Bargain.
Share this post
Link to post
andyj007
what extra do i need to mount this in my 2019 fw blacktop.  in leu of teh type 9
Share this post
Link to post
LoneWolf
Pretty sure it's not a straight swap. You need at least an adapter, the bellhousing is not removable, and I've seen none available.
Share this post
Link to post
John
or change to a Duratec engine
Share this post
Link to post
Steve (sdh2903)
Retro Ford do the bits to mate a zetec to this box. Youd need the adapter plate, flywheel and clutch and possibly a new chassis mount for the gearbox. And your prop would need modifying (or a new one)
By no means a straight swap but is a great box, will take a load of power and would still end up cheaper than a bgh or spc type 9.
Share this post
Link to post
https://www.retroford.co.uk/wp-content/uploads/2020/01/MX5-Gearbox-Technical-Guide.pdf
Share this post
Link to post
andyj007
thanks,  adapter plate ok,  making new plate on chassis ok,  prop get a new one made ok ,  ive just got a new super lightweight ttvflywheel, for my type 9 wonder what id need for matching these two?  type 9 is a pretty rubbish notchy change compared tho the mazda, i have tried thats the only reason i would like to change
Share this post
Link to post
