S2000 2005 belt tension pulley
Barnsley John
Barnsley John
just been finalising some winter checks and took the drive belt off
the tension er pully seems to have some ware  and i can wobble it about side to side
so i reckon get a new one
typed it up on e bay but see plenty of pulleys but arent saying specific to my engine  so before ordering and getting it wrong any help please belt as 6 ribes
and here are a few pictures any help will be great-full thanks john
Link to post
Si.Dalziel
@Barnsley John the tensioner pulley bearing is easy to change if it’s that. Beware it’s a left hand thread on the pulley though.
Im not using mine at the moment so if you need a comparison I’m happy to dig it out. I can also find the bearing part number if you want.
Or put your car on a diet and remove it all together.
much better!!!
Link to post
Si.Dalziel
3 minutes ago, Barnsley John said:
Thanks any help
Helps
send me a video of the movement you have and I will compare to mine tomorrow.
Link to post
Barnsley John
ok
just took it off and it does grumble a bit when spinning on your finger but can easy refit to show play
Link to post
Si.Dalziel
@Barnsley John that’s the exact video I used
And ordered 2 bearings as the one in the idler pulley is exactly the same.
both press in and out with a socket just watch you support the pulley properly and don’t damage the edge and remember that the tensioner is left hand thread and it’s an easy job
Link to post
Barnsley John
sorted out  with new bearing and refitted thanks
Link to post
Si.Dalziel
That was quick!!!!
Link to post
Barnsley John
yep nipped into bearing place about 3 mile away he took a look and said here you go old guy from proper engineering background 6 quid
took to mates with a 50 mm pipe for rear of pulley and a socket for front in and out in 2 minits refitted to car all in all about 5 min work and  30 min drive
 thanks for your help john
  • Like 4
Link to post
  • 2 weeks later...
CraigHew
@Barnsley John
thanks for posting. Both my tensioner and idle pulley bearings were worn (lots of side to side movement and noisey when spun) so replaced both this afternoon.
bearing part numbver:  2 x SKF 6203-2RSH  @ £3.95 each
literally a 10 minute job.
Also discovered that the S2000 tensioner has a wear indictor mark to show if your serpentine belt needs replacing.  (photo off internet: not my car)
every day is a school day...!
Link to post
Rich201060
Will this still be accurate with the A/C pulley missing, I guess we need a new belt ?
Link to post
CraigHew
Fair point Rich. The standard s2k belt running all 6 pulleys is 1470mm.
The 5 pulley configuration, with the a/c pulley deleted is 1138mm
This gives a difference of 332mm or just over 25%.
So to account for the  percentage difference (in belt stretch) I suppose the maximum indicator mark should be treated as 25% less: ie when the wear indicator shows a 75% movement.
Link to post
Rich201060
It's too cold in the garage else I was going to check mine to see if the bearings need changing, sounds cheap and worthwhile.
Link to post
Barnsley John
i changed belt anyway
and i keep the old one under bonnet just in case the new one brakes or shredes to get me home
tights are hard to find on side of road these days
unless your in gods country barnsley where they never stop on
but will still check mine tomorrow for interest thanks for the picture
Link to post
