Martin Rice (Sparkymart) - Cornwall AO
Electric mirror info
I've managed to get a set of MGF electric mirrors and a switch for them(land rover discovery) nice and cheap for a winter upgrade. Has anyone got any info on the upgrade regarding the wiring circuit and fitting? I've looked on the search but can't seem to find any info
Thanks in advance Martin
Share this post
Link to post
Steve (sdh2903)
Share this post
Link to post
Many thanks @Steve (sdh2903) :yes:
Share this post
Link to post
Nic (NICO) - Shropshire and Mid-Wales AO
Martin have a look on Kugawestie’s build blog. He fitted them to his original car. There is a comprehensive explanation.
Share this post
Link to post
TableLeg
Although you may find some of the photos blurred out.
Share this post
Link to post
Thanks guys that should be enough to get me sorted 👍
Share this post
Link to post
corsechris
I found a diagram of the wiring if you need it.
Share this post
Link to post
Robert (bombero)
Hi Chris, I'm wondering if I could get a copy of the wiring diagram, please..
Share this post
Link to post
corsechris
Certainly - I'll dig it out later and post it up.
Share this post
Link to post
corsechris
Here it is. Bear in mind it's from a German source so passenger/driver are reversed. The terminals on the switch are labelled so its easy to figure out.
Share this post
Link to post
Robert (bombero)
Ah thanks, that's the one I've already got (hoped that you might have a different one just to get as much info as possible.
I think I'm understanding it but for the bit that I've highlighted in red. I'm getting the ignition live (fused) and running it to Switch Motor (S156) but I'm not clear on what Header 0288 (K109) is? They look lime they're just for the mirror heading element which I'm not using so, I'm assuming that I'll connect straight to the switch via ignition live (fused)?
Share this post
Link to post
corsechris
Yep, the header is just a 1 in 3 out junction to split the switched 12V. Ignore the heater wiring if you aren't using them. I was surprised to see they run all the time TBH. Expected them to be switched along with the rear screen demist.
Share this post
Link to post
Robert (bombero)
I find this odd too and strangely, I believe it's quite common as far as I know. I'm sure my old TT was the same 🤔
Thanks for confirming re header 👍
Share this post
Link to post
BugMan
