Sign in to follow this
Dave1954
Fuel pumps
Dave1954
Hi I’ve 2 fuel pumps on my red top on throttle bodies, one at the rear & one under bonnet,someone suggested it could be a low pressure one at rear, high pressure at front is that correct I’m going to buy spare ones I’ve been stuck before with electric pump failing,   What are the best reasonably priced pumps& what pressure should they be ,  thanks. Dave
Share this post
Link to post
SXRORY
you need high pressure for the injection on the throttle bodies.
I have two pumps
I have one low pressure facet carb pump, this fills the swirl pot.  Then I have a high pressure pump in that pot to feed fuel injection.  My injection fuel pump arrangement is off a mk2 golf gti.
If you find the pumps you should be able to find out what they are from numbers on them (with any luck)
Share this post
Link to post
