Change of steering wheel
Mark Bishop
Mark Bishop
Hi all
Help and advise please?    i have a 1998 SEiW factory built with the original steering wheel (300mm) on it. I was thinking of changing to a Momo team wheel 280mm as i like the look. Will this work ok do you think?
Also do you know what boss i need? i am unsure as to where the original upper rack is from? i would ideally like a quick release one. Any recommendations?
What problems am i likely to encounter?
Many thanks
Link to post
Mark Bishop
Thanks. That looks a neat bit of kit, i will look at their site. I just need to find out what steering rack i am going onto??
Link to post
Kevin (Mr T)
If you go the Playskool route and the rapfix quick release (which I did) all you need to do is send Luke the upper part of the column and he can weld the rapfix connector to a reasonable sum.
Link to post
15 hours ago, Mark Bishop said:
Hi all
Many thanks
I swapped  for a go race quick release as you can buy the top half of the steering column machined to suit their quick release. I wasnt keen on using a welded on part and the swap is very straight forward
Here's a photo of the original column ( left) and the go race column(right):
Here's the q.r
Here's the underside. As i have a Mota Lita wheel I needed the adaptor ( larger ring of bolts) but you won't need that with the Momo wheel. BTW the q.r unit is also available in black.
Link to post
TableLeg
I too have the Go Race column and hub (in Black). Excellent bit of kit. I'd highly recommend it.:yes:
Link to post
