TableLeg
Pre IVA visual checks. Are these ok?
TableLeg
Can anybody please tell me if the harness adjuster buckles on the straps behind the seat need to meet the radius test?
If so I'll try and design some covers and 3d print them.
I should add, I already have boots that cover the harness attachment points.
Share this post
Link to post
AdgeC
Personally I'd err on the side of caution and cover them. Could you not extend he "witches hat" buckle covers, or make a simple stretch material sleeve.
Although I'm sure you want to demonstrate your 3D printing prowess again :rolleyes:
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
Er, do those fit with the seats fully back? I had a set of similar at one point, and they touched the back of the seat before the belt was pulled taught if you see what I mean.
Share this post
Link to post
TableLeg
Thanks Adge, That would be one solution for sure. The boots I had made for the fixing points I designed and cut myself but not having any sewing equipment took them to somewhere and paid for them to be stitched. I'll definitely look at how easy that would be to do. I could cut some material and take them and get them stitched to the originals.
Won't be able to do that until next week as the place I took them will be closed until Monday.
:yes:
Share this post
Link to post
TableLeg
The passenger seat is fully back, the drivers forward a bit. I'll go and double check the clearances when fitted.
Share this post
Link to post
TableLeg
Dave,
They don't touch the seat but the passenger side (fixed seat al the way rearwars) is close but doesn't actually touch.
Is your concern that they cannot touch the seat?
Share this post
Link to post
TableLeg
I have changed the title of this post as I think It'll be easy to detail any Pre IVA queries I have all in one place.
Another query, any thoughts on whether the mounting plate would or would not be ok here on the mirrors cage mount?
20190908_161734.thumb.jpg.d079e49960cec7a969fddf85e6fc0e44.jpg20190908_161741.thumb.jpg.42a4f2d98e3de2c09686882969a96776.jpg
If not I could try and add some trim of print some covers for them.
Share this post
Link to post
1 hour ago, TableLeg said:
Dave,
Exactly, they can't touch the seat*, or the seat back must become a stressed member to act as a support, (which in our case it can't). The key bit, is that if the seat is adjustable, it can't touch with the seat all the way back.
*thats simplifying it somewhat, it's not the same as the belt resting on the seat grommet.
Share this post
Link to post
TableLeg
Thanks Dave,
So They are fine with me in the drivers seat, but only in my normal driving position. Both seats (drivers in the rear most position and passenger fixed in the rear most position) both make contact with the buckle at the seat cutout hole. ☹️
So unless I can adjust them so that the buckles are through the seat cutout holes to start with I guess I'm going to need to buy some more harnesses for the IVA.
:no:
Share this post
Link to post
TableLeg
Another query,
What have people used to give the nut on a lambda sensor a suitable edge for IVA?
Share this post
Link to post
Steve Smith - AO Hampshire And Isle Of Wight
I did not do anything to my lambda nut and it pass IVA ok.
Share this post
Link to post
Thanks Dave,
:no:
Or fit a blocker bar in the seat tracks so that the seats only slide back to the position you want!
Share this post
Link to post
TableLeg
Thanks Dave, Unfortunately that won't work for the fixed passenger seat. ☹️
Share this post
Link to post
TableLeg
Ok so a slight update, I may have overlooked something obvious which was pointed out to me by the harness supplier.
Tonight I loosened the shoulder strap slider, slid it through the rear seat cutouts and forward enough that they now sit on the top of my chest after the hole cutout rather than behind it.
I can't say if this would be uncomfortable but so far as the buckle slider itself will pass the IVA tests I can live with it for now.
The only thing I can think now is to check that the drivers seat in its fully forward position doesn't foul the seat cutout. If it does, then like Dave suggests maybe some form of locking device to prevent the seat from sliding forward.
Share this post
Link to post
Chris King - Webmaster and Joint North East AO
That top pointy bit might just get caught in the radius test. Better trim or cover it to be safe.
Share this post
Link to post
