Ricky444 Posted August 31, 2019 Share Posted August 31, 2019 https://www.pistonheads.com/classifieds/used-cars/westfield/other-models/westfield-seiw-2-00-269bhp-2007/9897878 Hi Folks anyone one know anything about this car cheers Richard Link to comment Share on other sites More sharing options...
SootySport Posted September 12, 2019 Share Posted September 12, 2019 Don’t know the car but some pointers for you to check - Is it road registered and IVA ‘d. Does it have a straight cut gears, they are hard to drive on the road and noisy. It does have all the right parts that Westfield owners look for. The tyres are Toyo R888R soft compound and are very grippy. I have the same engine and they well suited to 7 type cars but mine is not tuned up to this ones level. It should be dry dumped at this power level. Engine and chassis numbers may not match which is not a problem, race cars are often having parts changed due to accidents and breakages but do check the chassis frame has no dodgy welding. Its a bit cheaper than the going rate for a well tuned Westfield providing everything is on the button. It will change your idea of speed if you test drive this one, go steady and hope you buy it. Regardd Bernie. Link to comment Share on other sites More sharing options...
Kingster Posted September 12, 2019 Share Posted September 12, 2019 4 minutes ago, SootySport said: Is it road registered and IVA ‘d. It is on a Q - see pics. 5 minutes ago, SootySport said: should be dry dumped at this power level. It’s got a dry sump 6 minutes ago, SootySport said: Its a bit cheaper than the going rate for a well tuned Westfield £15k - certainly not cheap 😁 (but neither is a 260bhp+ engine & quaife box - so about right) Looks good - but obviously needs to be closely inspected. Link to comment Share on other sites More sharing options...
