Wild idle on Zetec Blacktop
Chris Broster - Bristol & Bath AO
Hello collective brain,
I am struggling to get this pesky westfield  back on the road after my fuelling/ignition issues.
 I too had this fault with my 1.8 Zetec - died on track at Castle Coombe - fixed in pits then spluttered on track so binned it.
ed on track so binned it.  Sadly died again and had to be recovered home
After checking all electrics and fuel etc etc worked again? But then failed on M5 heading to Stoneleigh....
Same thing as you with spluttering and coughing then run down.
I did however find that one bolt from the throttle linkage mounting was missing on the ITB and this was causing the linkage to swing when accelerator pushed. Great service from Jenvey - replacement free and next day delivery.
I have now...
Replaced fuel pump with new Walbro one from Glencoe - Speak to Terry, great service https://www.glencoeltd.co.uk/  (Actually, higher spec for less)
Fitted new Sytec in-line fuel filter - again from Glencoe
Replaced all hoses with new Cohline fuel lines - Glencoe
Checked all relays are working when and how intended - pre-ignition and ignition
Checked all fuses
Checked all Earth connections - removed, cleaned and refitted.
Refitted vacuum pipe to Fuel Pressure Regulator
Replaced all spark plugs and checked for spark etc
Checked injectors are firing ok.
The result so far is that the car now starts and runs but is currently ticking over at 3000! This has been adjusted down from 4000 by winding in the throttle cable seat (result of reattaching the throttle linkage).
So now it is firing again my remaining issue is that on start it races up to 3000 rpm and if I blip the throttle or accelerator pedal it rises but then settles back at 3000?
Engine is 1.8 Zetec Blacktop with Jenvey ITB and MBE ECU.
I have tried winding the throttle cable to absolute slack and no joy.
I tried, gently, lifting the throttle linkage back to try to 'back it off'. The best this did was drop revs by 200? As soon as took pressure off it went back to 3000 plus?
I’ll try to upload video of start, revving and fall back to idle.
I haven't messed with ECU since it was mapped at InterPro in April.
The only thing I think of left to check/change is Throttle Position Sensor.
Anyone  got any experience, ideas, Jenvey set up instructions or 'how to set idle guides'?
Cheers Chris
Link to post
Geoffrey Carter (Buttercup)
I don't understand engines but I had a similar issue with my revs for a couple of days.
I had a spring on my throttle cable return that was missing.
Link to post
 Cheers Geoffrey
Don't suppose you have a before and after pic?
Chris
Link to post
15 minutes ago, Chris Broster - Bristol & Bath AO said:
 Cheers Geoffrey
Chris
I am on bike carbs but not sure if you would have a spring or not.
Link to post
DamperMan
Reconnected Vacuum pipe to fuel regulator??????    I believe the regulator should be open to atmosphere on naturally aspirated engines.   The pipe tail is only connected with turbo/ supercharged engines as it allows fielding to be increased with boost pressure.
Link to post
Kit Car Electronics
Chris, this should be quite simple- no matter what fuel or spark you have, the engine won't idle at 3000 unless you have air, and quite a lot of it. So you're looking for throttles that aren't shut, a throttle bypass channel that's open or a leak to the intake manifold.
Link to post
ainsworth
Hi
I had a worn and fraying accelerator cable with the broken strands catching on the sleeve going through the bulkhead wall. That made mine idle at 3000 revs because the cable was not retracting enough.
So might be something simple to check.
Link to post
Ok will disconnect again and retry?
Link to post
Aye that’s what I thought, but butterflies appear closed? I’ll get a torch shone down there and retry?
Link to post
33 minutes ago, ainsworth said:
Hi
Hadn’t thought of that so will get down and check full run of cable.
Link to post
the stoat
I also found a lack of lubrication on the cable can cause this.  It is amazing how little throttle opening is required to have a high idle.
Can you easily disconnect the throttle cable to test?
Link to post
Trevturtle
As said above.   3000 rpm means air is getting in.
If the throttle butterflies are all closed (check them all the left and right hand pairs may be out of balance ) the remaining options are
1. Throttle  bypass  air bleeds.   On top of each throttle body
2. Leaking inlet manifold
It will not take much opening  of the butterflies to get 3000rpm will no load
Link to post
@the stoat and @Trevturtle
Thanks again.
Plan for tonight is to:
  1. Disconnect Throttle cable and test
  2. Lubricate throttle cable at pedal, pedal box bulkhead, throttle linkage
  3. Lubricate all of Jenvey throttle linkage
  4. Clean internals of throttle body trumpets - some soot deposits in 1&3
  5. Cover/block and test throttle bypass bleeds
  6. Try to check Manifold air tightness??? not sure how but worth a try?
Stand by for feed back - if it fixes it you'll hear me whooping!!!! if not then I'll be crying into my air filter!
Link to post
the stoat
To test for leaks in the inlet spray the outside with something flammable like carb cleaner, if the revs rise you have a leak and if they don't there is no leak.
Link to post
Trevturtle
Thanks again.
Apologies for the dumb/ insulting question  ...☺️  @Chris Broster - Bristol & Bath AO
You have tried turning the idle screw down?  Its in between the centre 2 throttle bodies..  I can send a picture of it if it helps.
Sorry if you've  done  this already And i missed  it
Link to post
