Glove
Tyre pressures for a Seight 15" Wheels
Glove
Morning All,
My Seight passed its MOT this morning and I have had an advisory on the rear tyres (Which I knew needed changing soon).
The MOT technician mentioned the rear tyres had been over inflated because they have worn in the middle faster.
I had a search on the forum and did see a post that the tyre pressures on a Seight should be below 20psi. I have been running mine at 25-26psi.
I've just fitted new rear tyres and wanted to know the correct tyre pressure for road use and I enjoy cornering :)
I was thinking 19psi on the front and 18psi on the rear and comments/advice?
I'm running
Toyo Proxes R888R
Type sizes
205 R15 50 Front
225 R15 50 Rear
Share this post
Link to post
TableLeg
I believe somewhere in the region of 18psi to 20psi is the norm for Westfields.
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
As above, not for the SEiGHT specifically, but some run as low as 16/7 psi, (Personally I’ve Always found 17 a bit low).
Start around 18 or 19 and experiment with a psi or two, either way, from there. Driving style and car set up play a part too, so there’s less of a golden pressure, more of an ideal range, IYSWIM.
  • Thanks 2
Share this post
Link to post
Captain Colonial
According to the Seight build manual, it’s 20 psi + or - 3 psi.  I’d start with 20 & 19 and play from there with a big V8 lump on board.  It will handle better but be harder to park at low speed.  25 psi too high, you will notice an improvement in handling for sure.
http://www.manikllc.com/manuals/Westfield_SEi_construction_manual.pdf Page 90
  • Like 3
Share this post
Link to post
Labrat
I run mine at 18psi all round on T1Rs (according to my pressure gauge anyway).
Share this post
Link to post
Mighty Mart
Obviously its a personal thing, but I reckon you will be in for a pleasant surprise dropping to circa 20 psi from 25 - it should feel massively better imho.
I remember having my current R888R's when they had just been fitted, and had (unknown to me) been pumped up to 32psi..... I rushed home and chucked them on the car, ready for the following morning early start .....this was the drive up to Stoneliegh a couple of years back, and it felt like the back axle was loose and about to come off at every corner!
Letting 13 psi out was the difference of night and day lol....
Mart.
Share this post
Link to post
CraigHew
As above, I run R1R 205 50 15s at 18 psi all round.
Share this post
Link to post
marcusb
I ran my SEiGHT at 18 psi front and rear on 205/50/15   225/50/15
r888 and r1rs
Share this post
Link to post
groucher
I've ran my seight with 18psi since year one, sure the factory told me in the first year that 18psi was good, and I've used it ever since.
Toyo 888 tyres, before that avon CR55's I think, never had a problem with tyre wear, 15ins wheel & tyres.
As the car isn't has heavy as a tin top, I supposed normal rules don't apply, whatever you and the car a happy with.
regards
scott
Share this post
Link to post
Glove
Thanks everyone for the sound advise, I went out last night again for a blast and settled on 18psi all round.
It feels like a different car, unbelievable what the difference is.
Sun is shining so time for another blast👍
  • Like 4
Share this post
Link to post
