Vented discs
cast iron
cast iron
Properly boiling my front brakes this weekend at Knockhill
Are vented discs on the front a standard disc form a road car? If so which model please?
Link to post
CraigHew
My S2000 uses ventend and groved discs from an Escort Mk 2 Vented Disc (Std Grooved) 283mm.
HiSpec produce them but as a company they're b*stards to deal with...
You'd need to check which discs will fit your calipers too, unless you're going to uprate them at the same time.
Link to post
the stoat
I would place a significant bet that this can be solved without changing the discs.  First thing would be fluid, when did you last change it? I like Gulf RF1000 and have never been able to boil it.
If you then still have issues look at the pads.  What pads are you currently running and what calipers?
  • Like 3
Link to post
cast iron
yes fluid is changed every 6 months. Knockhill is a short circuit with at least one massive step on the pedal every minute from 120 down to a second gear hairpin.
Carbotech pads
Castrol react dot4 fluid
Im not getting brake fade, the pedal pressure drops right off. 30 mins after the race back to normal
Link to post
AdamR
Even with bog standard Dot4 it shouldn't be boiling the fluid. Definitely not air in the system?
Echo comments about not needing vented discs.
Link to post
SootySport
What callipers do you have? Never known a Westfield to overheat brakes as you say.
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
From what I remember it wasn’t that uncommon for some back in the days of the Westfield race series.
Link to post
cast iron
It runs Hispec 4 pots M16 replacements on the front
Link to post
cast iron
started this year at Croft , driving a hell of a lot faster! I think ive found the limit, but still need to go faster!
Link to post
Chris King
On road no - but a local S2000 powered car would boil the brakes at Croft
Link to post
AdamR
There is your problem.
The pistons are too high up the caliper, this makes the pads wear at a taper. When hot the pistons bind up and leave you with spongy brakes, when cool everything feels 'normal' again.
I use quotation marks because brakes are always horribly spongy with those calipers, get someone else to press your brake pedal and check the flex!
Something else that may help improve your braking in general is doing some proper brake bias calculations at www.brakepower.com.
Link to post
SootySport
Exactly as above,  hi spec ultralight will flex and wear unevenly, been there and done that.   Solution was to return to the trusty Ford M16’s.
Link to post
