Ricky_B
Type 9 Gearbox question
Ricky_B
I am currently running a 4 speed ford gearbox on my xflow, however want to change this to a 5 speed type 9, I have seen one on eBay but it says it has a Pinto bell housing, can I just swap the bell housing over from my existing box or something else???
Also what over parts will I need to change?
Richard
Share this post
Link to post
Arm
Hi. You should be able to swap it over. One comment the type 9 is not a great box and although you get a 5th gear you get a crazy low first. Better to have the type 9 rebuilt before fitting and have the ratios modified to make more suitable.
Share this post
Link to post
Rory's Dad
Windy did mine with just a long first gear. Just makes all the difference.
Share this post
Link to post
Ricky_B
Sorry for the dumb question but a long first. Do you mean higher ratio first??
Share this post
Link to post
SootySport
Long first means the engine doesn't rev its nuts off at a slow speed.    Usual ratio for type 9 is 3.2 to 1 or thereabouts depending on which car it was originally fitted by Ford.   There are few revised ratio options available now from specialist Gearbox compamies such as BGH Geartech, SPC, Quiafe.   They range from 2.4/1  to to 3.2/1 .      2.7/1 is useful for a road car.
Have a look Ratio for examples of what's available
Share this post
Link to post
BillyPee
One thing to bear in mind is that you might find, like mine, that the extension stands proud above the chassis rail about an inch, so you have to get creative with the tunnel top.
As for other parts, you might want to consider replacing the clutch while you have the engine and box separated. I had BGH refurb and long first my Type 9 last year and I changed to a lighter TTV flywheel and HD clutch. Spigot bearing and clutch release bearing may as well be changed to. I don't know length of the 4 speed bell hosing but if the length is significantly different over the Type 9 then you might need a longer shorter prop.
Share this post
Link to post
KenP
Can't recall the exact details but I am sure there's a 'long' or 'short' input option on the T9 box and from memory you need the short but best to ask the question of someone with some really expertise
Share this post
Link to post
pistonbroke
Talk to Brian at BGH Geartech , what he doesn't know about type 9's just isn't worth knowing :t-up:
Share this post
Link to post
KenP
Agreed, that's what I did.
There is so info on their website Here
Share this post
Link to post
Dave Licence - Devon and Somerset AO
Correct, the long input shaft is for the V6 - short input shaft for everything else I believe. Longer first gear ratio would be a joy!
Share this post
Link to post
