Sign in to follow this
Matt_S
Zetec Bellhousing
Matt_S
Hi all,
I am taking my zetec engine (blacktop) out later this week to modify the bell housing because it’s rubbing against the footwell chassis. The bellhousing itself is the Sierra cast iron type (so pretty heavy) with a cable clutch on the drivers side and the starter motor on the passenger side and fitted to a type 9 gearbox. My question, before I modify it, is it worth swapping to an aluminium one like this one from Burton Power, has anyone used one of these and is it a direct replacement, I assume the starter motor housing will still need modifying to fit correctly.
Thanks Matt
Share this post
Link to post
jonjh1964
Posted (edited)
I've fitted one - needs the starter motor blister removed
7 Kgs lighter than the original.
I got mine from RWD Motorsport RWD MS Alloy
Edited by jonjh1964
added RWD Link
Share this post
Link to post
KenP
Is this what you need LINK ?  If you give them a call they would be able to advise you as to the best option.
Share this post
Link to post
Matt_S
The picture shows only four mounting holes, do you have to open up the fifth one or is ok to use just the four?
Share this post
Link to post
jonjh1964
The 5th hole for the gearbox isn't a mounting hole it allows a rod to come out of the gearbox on gear change - make sure you don't get it restricted with RTV.
Share this post
Link to post
Matt_S
Also on the RWD website the hole where the clutch arm comes through and the hole for the clutch cable is not machined is this something you have to do your self?
Share this post
Link to post
jonjh1964
Mine was done - ask them if you want to confirm.
Share this post
Link to post
Matt_S
Ok thanks, did you use a dirt plate in between?
Share this post
Link to post
jonjh1964
No, left it open with the original Westfield sump as that was how Westfield supplied it (would probably use a plate now however, now have a Raceline sump that closes the gap).
Share this post
Link to post
KenP
Best to speak to them about your specific set-up as they do various options. I found them really helpful when I bought mine.
Share this post
Link to post
Matt_S
Ok will do thanks
Share this post
Link to post
