Here are a few bits that i bought and haven't ended up using. All will be at Stonleigh today:
Alloy racing fabrications 1L bulkhead mounted swirl pot and custom bulkhead bracket to mount directly above the diff . 8mm inlets and overflow outlet, 10mm pump outlet only used to start my new engine. Then I decided to use an in tank pump and keep my boot
SOLD
Fuel pump . Bought from Matt lewis racing. To include ant-vibration sleeve and aluminuum bracket. Again only used to start the new engine. 10mm inlet 8mm outle
SOLD
Alloy racing fabrications header tank specific to the Westfield with brackets to suit scuttle angle. Absolutely gutted i can't keep this but fresh air blower has stolen it's space. 8mm inlet 16mm outlet
These are over £80 new and this one has only been warmed once.
NOW SOLD
Carbon effect front indicator/DRL lamp pods. Fit landrover type lamps. These have cuutston the sides for swept wing brackets £10 collected or posted cost
Heater hose 16mm id 2.6m long never used £10 collected or posted at cost
Finally for now used Facet cube pump. Was successfuly used as a lift pump to the swirl pot for my 200bhp duratec engine and originally my carb pump complete with inline filter
SOLD
More to come including fuel tanks ...
I'll have the header tank please if its not already gone! Will be at Stoneleigh tomorrow or else can try to figure out another way of collection/postage.
Hi Andrew
I won't be at stonleigh today, still available though. Postage would be £6.50 Royal mail.
Hi, interested in the swirl pot and fuel pump, do you have any measurements for the swirl pot thanks.
200mm tall overall including overflow pipe. 10mm diameter and the bracket is 180mm across.
Hi, if the lift pump , swirl pot and fuel pump aren't spoken for can I have them?
Jim
Pm sent
Jim
Hi Jim,
Yes you can. Pm sent
