searsy Posted April 15, 2019 Share Posted April 15, 2019 (edited) I’m selling my 2016 Westfield SEiW BODY WORK Electric blue gel coat, FW nose / classic rear c/w detachable rear arches Playskool carbon effect rear light clusters Playskool MSA roll bar Full heated windscreen Venom multi-function headlights INTERIOR Westfield sports seats (black with blue trim) 4-Point Titon harnesses (blue) Westfield “IVA” steering wheel Westfield black vinyl dash / branded dials / switch set Black carpet set ENGINE AND DRIVE TRAIN 2lt Zetec c/w Omex throttle bodies & Tiger Racing ERA sump Omex 600 ECU “Standard” Type 9 gearbox (second hand) c/w Quaife Sierra 5-speed short throw gear lever. Ford 7.5” Diff – 3.64 ratio (Not LSD) Light weight Nippon Denso motorsport alternator (RetroFord) Team Dynamics Pro Race 1.2 black wheels c/w Toyo 205/50/15 R1R’s Westfield 4-1 Exhaust / CAT Westfield wide track adjustable front wishbones Protec Alloy Bodied Adjustable Shocks 2.4 Quick Rack Steering (rally design) Westfield branded “Hi-Spec” black brake calipers High efficiency alloy radiator (Coolex) OTHER DETAILS I built the car myself over two years using new components with the exception of the Type 9 gearbox which was brought 2nd hand. The car starts / runs well and I’ve had no issues in the mileage completed so far. There are some small cracks in the gel coat around the cycle wing mounting bolts and there is a small repair to the rear near side wheel arch (in colour coded gel coat). Registered: Oct 2016 (66 Plate) Current Mileage: 1900 Asking Price: £14,500 Edited April 27, 2019 by searsy Car now sold Link to comment Share on other sites More sharing options...
jonjh1964 Posted April 16, 2019 Share Posted April 16, 2019 Lovely looking car good luck with the sale. Did you get the springs from Westfield as white ones normally go at the back and black ones at the front? Link to comment Share on other sites More sharing options...
searsy Posted April 18, 2019 Author Share Posted April 18, 2019 Hi Jon, Many thanks - I'll be sorry to it go but time for another project! I got the shocks / springs from Protech at one of the Stoneleigh shows they, were marked Front and Rear, but now you've got me questioning this I believe they should be 7.5" / 300lbs at the front and the rears 9" / 175lbs will double check at the weekend! Thanks Keith Link to comment Share on other sites More sharing options...
jonjh1964 Posted April 18, 2019 Share Posted April 18, 2019 3 hours ago, searsy said: Hi Jon, Many thanks - I'll be sorry to it go but time for another project! I got the shocks / springs from Protech at one of the Stoneleigh shows they, were marked Front and Rear, but now you've got me questioning this I believe they should be 7.5" / 300lbs at the front and the rears 9" / 175lbs will double check at the weekend! Thanks Keith If you've got 300 front and 175 rear then they're correct and it could just be that Protech have a different supplier who uses different colours. Link to comment Share on other sites More sharing options...
Steve Smith - Joint Hampshire & IOW AO Posted April 18, 2019 Share Posted April 18, 2019 Hi Keith. Sorry to see you are selling your car. It would be good to see you at the Bun Penny before you sell it. Steve. Link to comment Share on other sites More sharing options...
MrPid Posted April 19, 2019 Share Posted April 19, 2019 I thought I recognised Cams Hall in the pic! Lovely Car, slightly out of my budget - Good luck with the sale! Link to comment Share on other sites More sharing options...
searsy Posted April 22, 2019 Author Share Posted April 22, 2019 Hi MrPid, yep Cams Hall, many thanks and good luck with your search Link to comment Share on other sites More sharing options...
