Rich201060
IVA 8th March
Only 2 weeks to go so as promised here's some images for scrutiny:
Share this post
Link to post
Looks good. Sure you have, but just in case: Have you checked the outer end of the silencer clamp bolt can't be contacted by the "cone test".
Share this post
Link to post
Looks great. One thing I would do, is if you have any rubber edging left, to put it either side of the ecu tray . It should just take any argument out :t-up:
Share this post
Link to post
Do you mean the hexagon end, If so Its facing down at 45 deg so not sure. If I'm honest I don't understand the cone test fully .
The ECU tray is made from 8mm nylon with a radius on the edge, I didn't like the idea of the alli plate.I may just emery the edge a bit more though where the radius breaks out.
thanks guys.
Share this post
Link to post
I was thinking of the thread end of the bolt, not the hexagon head. May be the a trick of the photo, just thought the thread end may be projecting out underneath the clamp enough to be contacted by the cone. Sorry not explaining very well!
Screen shot below from IVA Manual Section 16, may clarify what I'm getting at with the cone. It's used to identify the "theoretical floor line" Any thing above this line has to comply with the requirements of Section 16 Exterior Projections. Under this line is considered exempt as I understand it.
Hope this helps, apologies if it's a red herring.
Share this post
Link to post
Yep, agree with Adge. You have a domed nut on the clamp so you have the option to rotate the clamp to a position so the other end is further in, therefore bringing it ‘inside’ the floorline.
Share this post
Link to post
I’m not sure if the S2000 is a different front end but my steering rack attaches from the bottom of the front hubs not the top like you have mounted them ?
I don’t have the manual to hand but I thought the mount chamfered in the hole if that makes sense.
Share this post
Link to post
@AdgeC Ok thanks I will check tonight I really should read the manual .
Share this post
Link to post
Yes the S2000 is different and its not the first time that's been mentioned, thanks for your eagle eye though.
Share this post
Link to post
IMHO it's useful to be able to to show the examiner if the opportunity arises that you have "looked" at the manual, but not profess to be an "expert" on it.
 Link to current manual: https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/738819/individual-vehicle-approval-inspection-manual-passenger-vehicles.pdf
Looks a bit daunting at 300+ pages, not to bad if you focus on the relevant parts though ;)
Happy reading
Share this post
Link to post
Happy reading
I'd echo this as well, I actually pointed out items I had changed or modified and why I had done so.
Share this post
Link to post
Ok only a week to go:
What official stuff do I need this is what i think
Speedo certificate
Proof of appointment
Gonna take my laptop for build photos ie picture of harness fixings etc
IVA Test plate
Hobnobs !
Gonna take lots of kit and bolts pipe tape etc
Anything I've missed.
Rich
Share this post
Link to post
×   Pasted as rich text.   Paste as plain text instead
