CrisisWolf
Fuel Tank Top Electrical Connection Query
Had the boot box out today and was doing some suspension work and various other things. I noticed the earth cable Was disconnected. Odd thing is there are four terminals so I have two to choose from. I am assuming I knocked it off today, it may have come off previously, it may have never been connected. Anyone got the same/similar and can tell me where it should go?
Share this post
Link to post
Looks like the black wire is ground the black with red end is 12v and the green is signal, just see if the gauge is working.
Tony
Share this post
Link to post
Gauge works without it connected. Connected to either and no change. Odd.
Share this post
Link to post
My sender only has 12v and ground.  Could be it's for a different sender ,standard wiring loom and it's never been  used.
Tony
Share this post
Link to post
Seems to work. Will see if it starts and go thru old photos to see if its always been that way. Odd to have 4 pins on the sender, 3 on the wiring and only 2 connected
Share this post
Link to post
The route for the earth on the sender may be through the body/tank so perhaps the extra wire wasn't needed.
You could check that the continuity to earth of both the tank and the end of that lead to confirm.
Plus if the wire connector was connected to the sender I would expect the terminal it was connected to on the sender to be slightly cleaner than the others as it would have been in contact with it all the time.
Share this post
Link to post
I wouldn't be surprised if the terminals are actually marked on the nylon surround, but it won't be very clear. So you may need to thoroughly clean the body of the sender unit, and get a bright light on it, to look for markings.
The sender is probably working because it is earthing through the tank mountings. However it is good practice to have both the sender and the tank body separately earthed, as one thing you don't want with fuel tanks is the risk of a spark caused by an intermittent earth contact. It isn't good for your health.
Share this post
Link to post
Thought I'd have an old photo which caught the old connections but nothing clear enough.
The build manual however shows this:
So think I am fine. All seems to work. Both exposed terminals seem as dirty as each other so assuming not used.
Knew I'd forgotten a step!
Share this post
Link to post
Glad you got it sorted. Might be worth checking the Green wire to ensure it isn't still live (+12v ). If it is it'd be a good idea to cover the terminal with heatshrink or similar.
Share this post
Link to post
×   Pasted as rich text.   Paste as plain text instead
