Richard Houlgate
Sierra Viscous diff torque setting
I suspect that my diff may have been set too tight so I've taken it to Bara to investigate.
But what torque setting should it have? (Car is SeiW, 2.3 duratec, close ratio box, used in the Speed Series)
Advice welcomed!
Share this post
Link to post
180 Nm comes to mind as its what Steve's car had if I remember correctly
Share this post
Link to post
That's 130 ft lbs, Bara was talking around 120.
I guess this is a critical aspect of the set up (and an expensive one!), it will be interesting to know what the unit is currently set at, I'll report back.
Share this post
Link to post
Bara did my diff to 240Nm.
Share this post
Link to post
yes but you have a V8 with massive torque I presume
Share this post
Link to post
Barra did mine as well, works great, setting? haven't a clue.
I would have thought that it's not interested in what the engine puts  into the diff as the LSD engages when it senses slip between the two wheels. Or I missed the plot again?
Share this post
Link to post
Bara didn't know that though. Just his 'Uprated VC' setup.
Share this post
Link to post
Are you all talking about the same setting????
Share this post
Link to post
Bara reports that the diff was set to 180nm but is now 160. A it would cost £280 + VAT to have it altered I'll leave it as it is.
So the diff wasn't too tight after all and my slow corner exit excessive understeer must have another cause. Driver?!
Share this post
Link to post
Correction, mine IS set to 180Nm. 240Nm was the max with the standard plates on the 7.5" and 300Nm possible with uprated Nickel plates. Just checked my Email from 4 years ago.
Share this post
Link to post
Could be a lot of things, any videos?
Share this post
Link to post
No videos, the car is well balanced on fast corners but on tight hairpins as at 3 Sisters the car understeers when accelerating on corner exit. This can probably be avoided by a change in driving style I think.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
