Stu Faulkner
MX5 MK2 alternator question.
Am i correct in thinking that as the alternator on my MX5 MK2 engine has a 2 pin plug as well as the battery feed terminal that one of the pins is for the charge light and the other needs a 12 volt supply?
Share this post
Link to post
Is on mk1
Not sure if that helps lol
Share this post
Link to post
36 minutes ago, darve said:
Is on mk1
The wiring diagram that I have shows them to be similar.
For saying that the MX5’s have so many swappable parts there are so many variations when it comes to the wiring.
Share this post
Link to post
The alternator wiring is different between a Mk1 (NA) and a Mk2 (NB) engine
The NB alternator has a voltage regulator which I think the ECU controls. If you are using an aftermarket ECU, you could use an external voltage regulator to charge properly. Or use a Mk1 alternator depending on how the ECU is configured.
I think the plugs are the same though
Share this post
Link to post
Won't the MK1 still need a live feed?
As well as the battery connection.
Share this post
Link to post
Here's the wiring for the mk1 alternator:
So yes, from the main relay...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
