GaryD1971
Throttle bodies - Gsxr K5
GaryD1971
Hi All.
I've been given a set of Gsxr K5 throttle bodies to see if they can be made to fit my zetec engine. From what I can see so far, the spacing is 76 - 80 - 76 between the bodies but this isn't a problem as I am going to fabricate my own manifold. The thing I'm concerned about is the fuel rail doesn't have a return on it. The (very knowledgeable) chap I got them off said that modern bikes don't tend to use a return as it makes the fuel hotter and improves the emissions. Would this set up work on a Zetec? Or would I need to change the fuel rail for one with a return (if this is even possible). I am planning on removing the secondary butterflies and the actuator as this is the reason the bodies were given to me, the actuator is faulty.
Any thoughts from the collective?
Share this post
Link to post
Chris King - Webmaster
Share this post
Link to post
GaryD1971
That's excellent news!
Thanks Chris. Most helpful diagram too!
Share this post
Link to post
6 minutes ago, GaryD1971 said:
I assume its just a standard Tee piece in the fuel line before the fuel pressure regulator? @Chris King - Webmaster and Joint North East AO
Yup. Works perfectly.
Share this post
Link to post
GaryD1971
If you run from a sumped tank does this mean that you don't need a low pressure pump to feed the high pressure one?
I've seen a lot of systems that use a separate swirl pot which then needs a low pressure pump to feed through to the high pressure one.
Share this post
Link to post
Swirl pot is a better option
here is another diagram from my collection :d
I have both the swirl pot and dead head injection.
Share this post
Link to post
But no, you don’t “need” one...
Share this post
Link to post
GaryD1971
Thanks again Chris!
Share this post
Link to post
