Morris' XI Build
Morris
DIY-Si
Oh dear, thats a very expensive mistake avoided!! Leaking fluids in the dyno bay would not make you customer of the month! Maybe time to buy a new toy, I mean tool.
If you need to check your torque wrench, you can bolt the hex end in a vice and hang various weights from the handle end and see what torque the wrench clicks at. It won't make it work better, but it will tell you how far out it is!
Link to post
  • Replies 274
  • Morris
    142
  • jonjh1964
    29
  • Simon Marks - North Oxfordshire AO
    18
  • corsechris
    18
Popular Posts
There has been another flurry of car activity this week spurned on as I am starting a new job in a week’s time. It’s been good to be my own boss for a while, and I have been very busy catching up on D
Just a mini update this time as my tin garage gets a bit toasty when the sun is out!   I now realise why I was missing some parts from my Megajolt delivery - I hadn't put them on the order..
I’ve progressed a little with the pontoon storage containers whilst I wait for the flywheel and engine backplate to arrive. The external surface (which will be out of sight) looks agricultural, as the
Posted Images
Morris
Yes thankfully. I've already received 'approval' to get another wrench, and I've recently sold some more of the old Midget leftover parts.
Any thoughts on mechanical or digital? I guess (I could be wrong) that the digital type uses a strain gauge rather than a spring, so giving a longer length of service?
Having said that, I doubt I'll be building many cars in 30 years time...
I like the method of testing the accuracy of my current wrench. Like you say it won't fix it (and I won't be using it again anyway) but it'll give me a good idea of how far off it is.
Link to post
DIY-Si
I've never used the digital versions, so I can't really comment on them. I have always enjoyed the solid clonk the mechanical ones give when you reach the setting though. Given the use that any of us are likely to give one, I was always taught to leave the spring unloaded so that it should withstand longer use. No idea how that compares to the digital ones!
Link to post
  • 2 weeks later...
Morris
I'm getting a bit frustrated now as I am still without an engine, so I've made virtually no progress over the past month or so. I need it in situ to enable me to progress with the fuel/ cooling systems and the wiring etc. ☹️!
It should have been tested last week...
On the plus side I've ordered a new (Sealey) torque wrench which comes with a calibration certificate, so at least I'll know it'll start off with good accuracy.
Also I had some new tyres fitted (Avon ZT5 165/70 R13) to the replica Minilites that came with the MG.
Avon are running a competition at the moment to win a  Caterham 7 Academy car. Not sure where I'll keep it if I win, but I'll happily cross that bridge if I get to it...😀!
That's all for now!
  • Like 3
Link to post
Morris
My frustration is now over and I'm feeling very relieved!
The engine has survive its dyno testing with only a few issues along the way. A couple of core plugs were weeping slightly, and a stripped thread at the bottom of the timing cover needs dealing with to prevent a minor leak.
I don't have the graphs yet, but it produced 101bhp at 6500rpm and the torque peaked at 90ft lbs. The oil pressure was a bit high at 95 psi at 6000rpm, but I can reduce this by removing a small amount of spring from the pressure relief valve.
Interestingly, the testing was conducted using my manky old 45d distributor that came with the MG, so once I fit my Megajolt system I may be able to eek some more power out of it...😬!
Anyway, I'll post a graph of the test once I have it.
  • Like 5
Link to post
DIY-Si
Those sound like pretty good power figures! You clearly did a good job of building the engine, once the nuts and bolts were checked for tightness. 😉
As for the oil pressure, did you fit any washers with the spring to lengthen it? That used to be a standard trick to raise it on slightly worn engines. 95 psi is rather high, even for a brand new engine.
Link to post
Morris
Yes, thankfully all's well that's ends well!
No, I fitted the valve as supplied by MED (I used the ball rather than the cup type as they are less prone to sticking). My engine chap said it was only at about 6000rpm and shouldn't be a problem unless I'm really thrashing it!
I only spoke briefly to him over the phone so I'll find out more when I collect the engine (hopefully within the next couple of weeks).
Link to post
corsechris
@Moris.  Re the dizzy/power thing. The biggest advantage you’ll get from 3D ignition will be the driveability rather than peak power, although it is much easier to optimise peak power with mapped ignition than clockwork, so there may be a few more bhp to be found.
Link to post
Morris
Yes, to be honest the dyno measured power should be more than enough anyway (depending on where it all sits in the rev range).
Link to post
Morris
Now here's a nice original Lotus Series 1 steering wheel that has come up for sale in the US (on Ebay). Diameter is 14" and the leather rim is black (but well worn). Price is $204.49.
@DIY-Si Maybe good for someone with shorter legs or having the bench seat option. Would go nicely with the black interior of yours Simon to add to the authenticity of the Climax engine?
https://www.ebay.com/itm/153380024215
Link to post
DIY-Si
Morris,
Good spot! I shall keep an eye on that, but I suspect it'll go before I make my mind up. I'm currently hunting down guages and a Mk1 mini indicator stalk......
Do you know when you'll get the engine back so you can progress?
Link to post
Morris
@DIY-Si With a bit of luck I'll collect it next week as I'm off work over the half term week. Mind you he hasn't invoiced me yet so I guess I'll need to settle up with him first.
In the mean time I've started to assemble the clutch lever and slave cylinder mechanism. I thought it would be a quick job, but gave up as the pocket milled into the bell housing is a little undersize for the supplied actuator arm pivot bracket.
Some fettling will also be needed to enable the slave cylinder to sit correctly.
My enthusiasm will no doubt return once I get my engine back 😀!
Link to post
jonjh1964
Morris,
I used a grinder/flap disc to get the slave cylinder to fit, clear the chassis around the starter, clear the larger 1275 oil pump and finally (perhaps 2) of the gearbox/bell housing bolt heads
Jon
Link to post
Morris
Thank you Jon,
It's all carefully designed to drop right in then...😀!
Morris.
  • Haha 2
Link to post
  • 2 weeks later...
I collected my engine this morning so now just to get it out of my boot!
Will post more in a while but in the meantime, here is the dyno output. It was tested up to 6500 rpm as that should be more than enough for my type of driving.
I am not clued up on how the car will drive in relation to power delivery (bhp vs torque vs engine rpm) so any pointers on decifering the graph would be very useful.
Many thanks.
Link to post
