1994 Westfield SEI Wide Body in White SOLD
chrisp
The time has finally come to part with my car, it has been with me since 1996 although in the
last eight years it has sat on the trailer in the garage.
I bought it as a basic car fitted with a mildly tuned Chamberlain 1600 Ford X flow. It was very
well screwed together by the man who built the car as he was planning to compete in it. I
intended to make it into a road car with carpet, comfortable seats etc however I quickly
realised that the Westfield Speed Series would be more fun and competed in it for 6 years.
During this time the following changes were made:
A new X flow engine was sourced and built by Vulcan bored out to 1700cc with large valves,
tungsten inserts, gas flowed high compression head, 244 cam, pocketed pistons, lightened
flywheel, balanced clutch, shot peened con-rods, balanced flywheel, clutch, rods, pulleys and
crankshaft, power grip pulley set, uprated oil pump, Cosworth big end bolts and steel cam
shaft straps.
Home made throttle bodies
Petrol tank modified for fuel injection
High pressure fuel pump
Inlet manifold fitted with fuel injectors
Emerald programable ECU
Crank shaft position sensor, water and air temperature sensors and throttle position
potentiometer fitted to supply inputs for ECU
Wasted spark ignition system
Nylon bushed chassis
Aluminium bell housing
Quaife ATB limited slip differential
Aluminium front uprights
Four pot aluminium front brakes, Hawk pads
Drilled and lightened front discs
AVO adjustable dampers
Front anti-roll bar
Quick rack, solidly mounted
Lightweight plastic seats
4-point Willans harness for driver
3-point Luke harness for passenger
Roll bar strengthened and extra bracing
Wunoff re-packable stainless steel silencer
Side screens and hood
Fitted fire extinguisher system
Geared starter motor
Gear change LED
Chassis ride height, corner weighting and geometry setup by Northampton Motorsport. Car
weight 571.5 kgs. Rolling road set up by Dave Walker at Emerald Engineering: Output 148
bhp at 6800 rev/min. 130 ft/lbs at 5600 rev/min.
In the loft I have high back padded seats, boot box and lockable lid, carpet set and underfelt.
The car comes with its own trailer, this is a home-made two wheel trailer which was
constructed to fit into a small garage, it tows very well.
Any questions give me a call: John Pearce tel: 01753 646703 or email: cpandjp@icloud.com
Price: £5000 ono
  • Like 4
Link to comment
  • chrisp changed the title to 1994 Westfield SEI Wide Body in White SOLD
John
Thanks for your help will keep in touch.
Dave
Link to comment
