Matta
Westfield SEiW C20XE Vauxhall 16v
For Sale - Westfield SEiW with C2.0XE Vauxhall 16v Engine
Summary:
Registered in 1997 (Q regd.) and it has done around 17.5K miles.
Originally factory built and sold by Terry Nightingale as an ex-demonstrator to former WSCC Chairman Paul Edden, then one other owner before me. I bought the car in May 2014. Fitted with a CVH when it left the factory but converted to the 16v Redtop by the first owner (engine originally built by Ash Mason I think but fully rebuilt in my ownership). I have lots of paperwork, including the original build manual and for sale advert.
The car was a regular competitor in the Speed series and hillclimbs until I bought it. I converted it back to ‘road’ spec (i.e. refitted the windscreen, wipers, interior trim etc.) and spent a small (or not so small) fortune getting it up to the standard I wanted. It’s only done one trackday at Knockhill in my ownership and plenty of road miles.
Apart from the engine rebuild (£3k+ with receipts) and regular maintenance, it’s also had new rear shocks, disks and pads, new brake master cylinder, Willwood front calipers, alternator, inlet manifold (SBD), headlights, fuel filter and hoses, re-plumbed and simplified cooling system (no heater), new cooler running thermostat, new R1R’s, Simpson’s exhaust box, front ball joints,  suspension set up and corner weighted. Basically, anything it’s needed has been done. MOT to December 2018 and next oil change also due December 2018. It's not an immaculate show car but is generally in very good clean condition, is reliable and has been maintained regardless of cost.
It has all the right bits, IMO, and is equally suited to road or track use.
This is my third Westfield and I had never planned to sell it but times change. PM me for a chat or email to mattdotalexanderatvirgindotnet if you want more information or pictures etc.
Engine:
C2.0XE Vauxhall 16v Redtop ~200bhp
Fully rebuilt  around 4000 miles ago. Early block with later head.
Re-bored and decked block with new forged Omega pistons, re-bushed steel Carrillo rods, ARP big end bolts, reground crank, lightened flywheel and everything fully balanced, including clutch. New oil and water pumps. ~30psi oil pressure when hot at idle / ~60psi at revs.
Rebuild stage 3 GM head with oilway mod (head was pressure tested and didn’t need it but was done as a precaution), skimmed, ported, new valve guides, new hydraulic followers and re-profiled cams (286deg/10mm lift). Standard valves. Head has water outlet if you wanted to add a heater.
QED alloy shallow sump (with 6mm alloy plate sump guard) and it doesn’t leak!
Webcon Alpha 3D ECU
Weber 45’s (152G) with Pipercross foam filter and twin throttle cable linkage
Vernier pulleys and new timing belt/idler pulley kit
SBD inlet manifold
SBD Stainless 4:2:1 exhaust manifold
Re-packable 7” ceramic coated Simpsons non-cat silencer (or optional re-packable lightweight carbon Techcraft one). Both re-packed with Acoustafill last year.
Rally Design oil catch tank (Alloy)
Facet Redtop competition fuel pump & Malpassi Filter King regulator (with new filter)
Lightweight Redtop battery
Denso lightweight alternator
Omex rev limiter (currently not used)
I can comfortably get 30mpg+ on a long run, 2-up with luggage and being (fairly) sensible. It idles smoothly around 1000rpm and pulls well in all gears. Sounds great with the Webers and big Simpsons exhaust.
Drivetrain:
Alloy-cased Quaife Type 9 5 Speed straight cut gearbox with long 1st gear (~50mph). Short input shaft version.
1st         2nd         3rd        4th      5th
2.040     1.540     1.210      1:1      0.870
Alloy bell housing
Westfield quickshift extension
Competition clutch (QED) - cable operated
Sierra Viscous LSD fitted 4.4:1 CWP
Suspension:
Cat Motorsport quick rack (1.5 turns) and wide-track front suspension with rose-jointed adjusters.
Disc brakes all round. Front - Cross drilled and lightened with Willwood 4-pot calipers. Rear - new grooved disks, Sierra calipers & new pads.  Adjustable brake bias from inside the cockpit.
TSW Stealth 7x15" Alloys with 195/50/15 Toyo R1R's
Front & Rear adjustable anti roll bars (front one is Cat Motorsport, not sure about rear)
AVO dampers with bump rebound adjustment (new alloy rears and new springs)
Body and interior:
‘Kit’ fixed-arch bodywork in original red gelcoat. Good condition for year with very slight crazing on O/S rear arch.
Windscreen and earlier, stiffer doors (don’t flex like the later ones), WF half-hood with storage bag. Metro mirrors.
Bootbox and full tonneau cover with centre zip
VDO instruments, keyless start and master RAC cutoff on dash
New capillary oil pressure gauge (original electric one and sender available)
Manual cooling fan override on dash (uses heater switch)
12v charging socket
Standard WF sports seats and 3” 5-point harnesses
Top-mounted pedals
Heavy duty removable fitted rubber floormats instead of carpets
Std 5” headlights with Osram night-breaker bulbs
RAC rollbar with rose-jointed backstays
Wide Westfield cycle wings (will easily cover 205’s)
Standard WF fuel tank with locking cap.
Quick release steering wheel
Optional aero-screen available.
I absolutely love the car and didn’t think I’d be doing this but I’m just not using it nearly as much as I’d like to for a number of reasons and it doesn’t make sense to leave it sitting in the garage. However, if it doesn’t go for the asking price, I’ll hang on to it.
Price: £9950
Located in central Scotland.
Share this post
Link to post
