Westfield XTR2 - SOLD
NDS
Westfield XTR2 Sprint / Hillclimb car  (THIS CAR HAS NO V5C )
Part of a car collection was in storage for many years
Full specifications
Chassis supplied by Westfield in April  2007
MSA  logbooked.
2006 Hayabusa 1300, dry sumped, HD clutch plates and springs, fitted with a Power Commander
Westfield front brake upgrade, vented discs with 4pot calipers.
Solid discs and calipers on the rear with inbuilt handbrake
Nitron shock absorbers.
Stack gauges.
Digital gear indicator.
6 point 3in race harness on driver's seat and 4 point 3in harness side.
2.5 kg plumbed in extinguisher.
Compomotive CX race wheels 8x13 front and 8.5x13 rear with Avon ZZ-S   Set of CX 7 X13” with  Michelin Pilot Sports  slicks 20/54
Foam filled fuel tank in N/S side pod.
Twin plane rear wing with carbon end plates – XTR4
All emission gear removed and a non "cat" exhaust
Flat Shaft Paddle system with flat shift. (Partly installed)
Spares and tools
Quick lift jack
Fuel churns
Spare Starter
Chassis stands
Oil
Recent freshen up in the Aerodynamics work shop.
New long  wheel studs and wheel nuts
New front lightweight alloy hubs and bearings run out checked
Brake fluid flushed
New Plugs
Oil Change
FIA rain light
Large race mirrors
Fasteners replaced with stainless steel
 We remove the front splitter for transportation. Based in Perth Scotland   £15,750
Link to comment
