IanReid
Mazda SDV build (Surrey Area)
IanReid
I'm building a Mazda SDV at a very leisurely rate in the Surrey area. I've created this topic to cover all aspects of the build I might need advice on.
First question is shock absorbers. I intend to use my Westie as primarily a road based car, with the possible the occasional track day. So my question is are the shock absorbers that Westfield will sell you the best value for money? I assume they OEM them, rather than build them themselves. Can you buy them cheaper elsewhere? Are there other alternatives?
Share this post
Link to post
EBD Engineering
i got mine from blink motorsport there protech shocks. the westfield ones im sure are fine but be aware buying shocks from somehwere else the lengths are different on the front to standard westfield lengths
Share this post
Link to post
Andy (Sycho)
I had mine from procomp which is another option.
Share this post
Link to post
John (Kernow)
Why not give @DamperMan a try as a club sponsor and owner of Spax I’m sure he will sort you out with what you need.
im surprised he doesn’t get more recommendations, all feedback  on here has been great and at least he contributes to the club.
  • Like 4
Share this post
Link to post
Kit Car Electronics
When I finally give up on my rattling Protechs that drive me nuts, I'll be trying Spax again.
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
Yep, I had new Protechs with my build, but given others feedback and his own comments, I’d be speaking to Damperman when it comes to replace mine, to give the Spax a try.
Share this post
Link to post
DamperMan
I’m a westfield owner, the main tech man also Md at Spax.   I try not to force sales or opinions.  Also don’t BS folk into thinking I know my stuff.   I don’t use the majority of the suspension jargon which makes people think it’s a black art.    I’m here primarily here as a Westfield owner.   I’m happy to help in any way I can.
  • Like 6
Share this post
Link to post
IanReid
Thanks for the replies everyone. I'm not quite at the stage of needing this yet, I'm just trying to do some homework in advance. Looking at the SPAX web site I can see the shocks they do for Westfields. Looking at the images these shocks don't have any springs? Is this right. Do you need to buy these separately?
Share this post
Link to post
DamperMan
Probably better to ask me direct than ask the forum :).   The dampers are supplied without Springs.   We make the dampers but don't make racing springs, these are bought in.  I can point you in the right direction.    Yours is a Mazda SVA so the dampers we list are not he same.       You can build the car replacing the shocks with a bit of wood with holes drilled in each end.    I can pop out one day and measure up the car and advise springs.  OR if a club member is able advise the lengths if the springs and dampers I can build dampers from that.        Tony_shakeshaft@spaxperformance.com
Share this post
Link to post
EBD Engineering
the mazda shocks are 14inches open length all the way around. if you need any sizes for anything tony let me know
Share this post
Link to post
DamperMan
If you know your spring rates, diameter and Bush sizes that would be a start guide.   I can calculate damping rates to work, and then the adjustment to fine tune.
Ideally if I measure a live car and weigh it I can come up with proper lengths, rates and set bumpstop lengths to keep the sump of the ground among loads of other considerations.
Share this post
Link to post
EBD Engineering
I'll have a look through my files for the dyno plots for the shocks they should have the info on them
Share this post
Link to post
IanReid
Thanks for the info guys. The message I'm taking from this is that it's probably best to sort out the springs and dampers when the car is nearing completion. As I'm not going to be in that position for a wile I will hold off for now. I'll use the length of wood suggestion for the time being.
Share this post
Link to post
IanReid
I've just ordered the ball joints for the front uprights and I read in the Westfield manual that you need a M18 1.5mm pitch tap to clear out any epoxy from the wishbone. Is this size right? I've looked at tap and dies sets on the web and they all seem to stop at M12.  Surely there's a typo there. BTW how annoying is that you need an imperial tap and dies set for the rear wishbones, and a metric one for the front. There must be a conspiracy with tool manufacturers!
Share this post
Link to post
Ianboom
I may be wrong, but I don't remember them being that big!
I certainly never had to run a tap through mine. Worth trying the ball joint in the wishbone before buying a tap, as long as there's no resistance threading it in, you'll be fine. Seem to remember having to buy the lock nuts separately though.
I don't think I had to run a tap over any threads during my build??
Share this post
Link to post
