SE FW ZETEC - New member/New build
tc3nitro
tc3nitro
44 minutes ago, BugMan said:
Have a look at this bit of my build, does this help with what your looking for?
I couldn’t see anything that coresponds to the issue I have.
I am missing the 2 x 30mm M8 bolts, nuts and washers.
Link to post
  • Replies 458
  • tc3nitro
    214
  • BugMan
    43
  • Dave Eastwood (Gadgetman) - Club Secretary
    27
  • Adge Cutler- Dorset AO
    24
Popular Posts
Another update tonight : My plate turned up, although I’m not that pleased with the spacing but it’s now legal!  Well sort of as I’ve not got a front plate nor am I planning on fitting one.
It’s alive ! Startup Video
Great but the traffic was aweful ! Just finished unloading and having some pizza ! here are the Pictures :
Posted Images
Robin (Red Spider) - Yorkshire AO
Definitely cracking on with it. We'll have to have a group meeting just like we did with Steve, @BugMan
Link to post
Would that be the K nut's I had to use?
Like a thin locking nut to fit on the cylinder flange ?
Link to post
tc3nitro
If you look at the pictures below my master cylinder attaches to where you have fitted the two blanking plates. I only have one blanking plate for the clutch side.
I hope this makes sense :-
Link to post
Gary Taylor - Scotland AO
There’s no stopping you now :d keep going, nice work
Link to post
wow you are catching me up already.   Looking good. If you have the mazda diff like me, it might be worth trial fitting the top and bottom diff brackets and check clearance for the fuel line going to the right ( will be going to left when turned right way up), looks like you may be a bit close to the diff like I was, moved fuel line further to right ( inverted) to make sure I could fit rubber fuel pipe on later.
Link to post
tc3nitro
Thanks for the advice. I’ll make that one of the next jobs.
Managed to get the loom laid out to a very loose fit, does anyone have any pictures of the loom fitted as the manual is poor in this area.
Link to post
Steve Smith - AO Hampshire And Isle Of Wight
Great progress. I did not fit my wiring loom until I had the diff fitted so you can check the route/clearance in the diff area.Have a look at my build for pictures.
Link to post
tc3nitro
Link to post
Rich201060
Heres a couple of mine showing the routing at the rear, I haven't got any decent ones of the front but theres plenty on here if you have a good look.
P1020415.thumb.JPG.fd81528c371f3b2fd85075ad1e44f094.JPGP1020455.thumb.JPG.4d3f4b81664991461e28580e721f984c.JPG
Link to post
Just check on your pipe runs down the tunnel that you have clearance to bolt up the rear gearbox?
I got caught on that and had to move it a little.
Otherwise, WOW what fast work, very good.
Link to post
tc3nitro
How could I check this without actually fitting the gearbox ?
Link to post
