SE FW ZETEC - New member/New build
tc3nitro
tc3nitro
16 hours ago, Chris King - Webmaster and Joint North East AO said:
As I always say a happy wife is a happy life! Works for me judging by the amount of carbon she’s bought me :d
Welcome to the club. I have the Aim MXS dash and a Zetec so shout up nearer the time for info.
Chris can you tell me which version of MXS dash I need to purchase ? Can or obd/k-line.
Link to post
  • Replies 458
  • tc3nitro
    214
  • BugMan
    43
  • Dave Eastwood (Gadgetman) - Club Secretary
    27
  • Adge Cutler- Dorset AO
    24
Popular Posts
Another update tonight : My plate turned up, although I’m not that pleased with the spacing but it’s now legal!  Well sort of as I’ve not got a front plate nor am I planning on fitting one.
It’s alive ! Startup Video
Great but the traffic was aweful ! Just finished unloading and having some pizza ! here are the Pictures :
Posted Images
Depends on ECU. My ECU supports can, so that’s what I bought. With can it’s just two wires from ECU into dash and then you can access all the sensors and inputs to the ECU and therefore no need for the AIM expansion unit at an extra £250 (or whatever)
Link to post
tc3nitro
It’s the omex ecu supplied from Westfield. I’m presuming it’ll be the 600.
Link to post
Mines a DTA - no experience of Omex, but very common to see the 600 used on the Zetec builds.
Link to post
The Omex 600, according to Race Technology at least, (for their ecu interface) is serial and needs to be on firmware v0.70D or later.
Link to post
RT also have some handy info here on how the ecu needs to be configured.
http://www.race-technology.com/wiki/index.php/ECUType/OMEX600And710
Essentially a preset stream of data comes into the display in sequence. In the display config, you then (presumably) need to tell the display what format the data is in, so it knows how to break it back down into individual channels. (This bit is essentially done automatically in RT stuff, as you have an adaptor matched to the ecu). You then just assign the incoming data channels that you want to use to display channels on the display device.
Link to post
Here you go, just found the matching page on the AiM ecu site.
http://www.aim-sportline.com/download/ecu/racing/Omex600+710_102_eng.pdf
so physical wiring aside, you essentially just set the dash to use a Gems ecu, (that’s what the Omex ecu’s are descended from) and then configure the channels you require.
Link to post
tc3nitro
Brilliant thanks !
What physical wiring would I require ?
Link to post
AiM list a part number in that manual for the lead. The Omex end is a male DB9 serial plug and a 3 core wire link’s it to the AiM, but I don’t know what connector the AiM has, without downloading its manual to have a look. It may be another DB9 but sometimes other connectors are used to save space.
Link to post
OK, a very quick look on the AiM web site, (that’s code for double check yourself before actually ordering!) Would seem to suggest that you get a Can bus harness with them as standard, but there is an optional serial harness. Whether this is an option box you tick when ordering so that you get one or the other, or whether they all come with the CAN harness and you have to buy the serial version as an accessory I don’t know, I’m afraid.
Link to post
Dash comes with connectors. ECU comes with connectors. I just needed to connect the two can +ve and -ve wires. Easy peasy!
Link to post
What serial connector is on the AiM harness? Or is is just bare tx, rx and ground wires?
Link to post
tc3nitro
You can buy the dash in 4 options race or street and then either canbus or obd/k-line.
Link to post
Yes that’s what determines the connectors you get.
Link to post
Not sure Dave.
Link to post
