Steve (sdh2903)
What have I done now..... V6 seiw build
CosKev
Nice:cool:
How high can you go on top?
Share this post
Link to post
Steve (sdh2903)
I reckon about 100mm from the base plate. I'm going for around 80mm height on the plenum to give a bit of wiggle room.
While waiting for some stray aluminium to be delivered to finish the inlet mock up I made a start on the bodywork.20190227_170636-2016x1134.thumb.jpg.ec17f048ff97b3d62b02e890edeebe68.jpg
A rather full engine bay
  • Like 6
Share this post
Link to post
Stu Faulkner
Wow.
Thats a bit snug.
Share this post
Link to post
DamperMan
Make it a bit taller!  Through the bonnet. And go mad max style ...
Share this post
Link to post
Adge Cutler Dorset AO
Welcome back Steve, more excellent progress. That inlet setup is fascinating, a credit to your ingenuity and fabrication skills. Keep up the good work.
Share this post
Link to post
BugMan
Clucking bell, i thought mine was tight :westy:
Share this post
Link to post
corsechris
2 hours ago, Stu Faulkner said:
Wow.
Thats a bit snug.
The exact same words ran through my mind too.
I hope those engine mounts are good and solid Steve! ;)
Share this post
Link to post
Steve (sdh2903)
Only one way to find out :d
Share this post
Link to post
CosKev
Promising news from Dave on LCBs after getting his car on RR:cool:
Running the ST200 inlet ,which looks the most restrictive to me,it's made 242bhp,and still pulling at the 7200rpm rev limit :t-up:
Share this post
Link to post
Steve (sdh2903)
Progress is plodding along. The inlet mock up is complete and will hopefully be sent away for finishing this week. Some spangly new shocks arrived courtesy of the ever helpful @DamperMan So threw them on.
Body has now been shuffled around to line of best fit and riveted in place. Which will now open up a load of work while I'm waiting on parts. Particularly the scuttle build (yay). I did end up with the tub maybe 10mm further forward than the book figure of 400mm but I wanted the wheels as central in the rear arches as possible. The bonnet needed a bit of a tweak too. So it's been strapped in place and gently heated up to hopefully get it a bit better fit. Excuse the garage I've left it a tip!
  • Like 9
Share this post
Link to post
Thrustyjust
Interesting shocks Steve . Any info on them ?
Share this post
Link to post
Steve (sdh2903)
Mr @DamperMan Will be able to say more. I just know they're spax! Some fancy progressive springs on the back though to try and not have the same issues as I had on the last one (as you did aswell)
Share this post
Link to post
DamperMan
@Thrustyjust  I don’t want to thread jump so pm me with any questions you have...
Share this post
Link to post
Steve (sdh2903)
Thought I'd start the dreaded scuttle build today. Now I had a bit of a head start here as I had sourced a used screen/wipers/heater off a sport250 owner gone aeroscreen so with being fitted before a lot of the fettling had been done. I have given the T7 design demist vents a go rather than the big fibreglass moulding.
Only query is whether the 3rd vent will be needed. They are angled and look like the airflow will converge about 4 inches above the bottom edge of the screen so hope they will be ok.
Also used one of the T7 heater bulkhead connectors aswell as I think it's a better option than just poking the pipes through.
Eagle eyed will spot the differing spindle angles, they are just slaved in for now ;)
after my bodywork strapping it seems to be holding in a better position now. Maybe just another quick heat and strap again to get it spot on.
  • Like 3
Share this post
Link to post
BugMan
+1 on the T7 fitting Steve :westy:
Share this post
Link to post
