What have I done now..... V6 seiw build
Steve (sdh2903)
Steve (sdh2903)
30 minutes ago, Matta said:
Nice looking pile of bits there Steve! How complete is it?
You might not make Applecross in June but definitely next year!
Matt
Hi Matt. Not very complete  few panels on and brake lines in and diff slaved in. I think I'm going to take it back to square 1 as the paint finish on the chassis leaves a bit to be desired.
Yeah June may be a push......
Link to post
  • Replies 829
  • Steve (sdh2903)
    317
  • CosKev
    105
  • corsechris
    47
  • Dave Eastwood (Gadgetman) - Club Secretary
    40
Popular Posts
A socially distanced pass
Well after 8 months with no westy in the garage I'm now the proud (Well ish) owner of  a lot of parts that may well, one day, end up drivable  A cheeky eBay bid later (not expecting to win mind) a
Not sure it would make much difference. The pwm bosch valve has very small increments of movement. A 1 percentage point of movement is almost impossible to see by eye.   Got back on to inter
Posted Images
Steve (sdh2903)
Noticed these bits (the cylindrical bits sticking up) on the bar where the harness eyes screw in. Can someone tell me what they're for?
Link to post
Chris King
Old skool inertia belts I think.
Angry grinder time :d
Link to post
Steve (sdh2903)
Ah makes sense. Cheers Chris. Like an excuse to make sparks:d
Link to post
Unless its already registered (I doubt it) you may need those mounts for IVA so check it out first before cutting  them off
Link to post
Steve (sdh2903)
No it's not registered. Why would I need them if using the ordinary 4 point harness mounts John?
Link to post
You don’t need them for IVA if using the harness mounts. (Plus spacers) as said they’re the top mounts for inertia reel seatbelts.
on later chassis, they’re optional and just screw in. On older chassis they’re huge lumps of solid steel, welded in. Oh, and normally, they go all the way through the top chassis rail! So you do have to cut right through them with the angry grinder, while taking care not to notch the chassis rail, by accident!
Link to post
Steve (sdh2903)
Apologies for the daft questions but this is  my first dealings with the zk body.
Ref the boot box below am I right in saying this is for a standard range tank as there's no step? Remarkably when unwrapping all the body it's in excellent shape. I'd actually say better quality than my 2016 bodywork.
Link to post
yep id say standard tank the one i had with my long range tank had a step to allow for th eextra height on the tank
Link to post
Aye, standard tank, and your right, bodywork hasn’t been a patch on the old stuff since it stopped being made in-house.
Link to post
Chris King
My ZK tank is around 28litres, so it’s big enough really.
Link to post
Steve (sdh2903)
Cheers chaps.
Apart from the main tub the rest is immaculate. No swirl marks and no where near as many imperfections. The main tub will need a good cut back and polish if I keep it red. Although seeing how good it is it would be a shame to paint over it.
Link to post
Steve (sdh2903)
Yeah sounds ok. The fw long range was only around 28. I'll keep an eye out for a standard tank coming up for sale. If not I fancy a custom one with a built in swirl pot and in tank pump.
Link to post
Adge Cutler- Dorset AO
Been out of circulation for several days, just seen this. Good to see you've started investing in the motor industry again!
Enjoy your new project, will be following with fascination.
Link to post
