Steve (sdh2903) 3,534 Posted November 23, 2018 Author Share Posted November 23, 2018 Yes you are right Chris. That price includes sensors and a loom for the 250. Still v pricey though. Quote Link to post Share on other sites
Dave Eastwood (Gadgetman) - Club Secretary 7,792 Posted November 23, 2018 Share Posted November 23, 2018 While pricey, I can understand it to some extent. The learning curve on pure digital dashes like these and the Race Technology is absolutely colossal; as a result, owners can need a disproportionate amount of technical support, and it can be complex support at that. That said, I bought mine from Plays Kool and just got stuck in! Quote Link to post Share on other sites
Steve (sdh2903) 3,534 Posted November 23, 2018 Author Share Posted November 23, 2018 1 hour ago, Dave Eastwood (Gadgetman) - Club Secretary said: That said, I bought mine from Plays Kool and just got stuck in! My plan exactly!.......... .......once I get financial approval that is 1 2 Quote Link to post Share on other sites
KugaWestie 3,339 Posted November 23, 2018 Share Posted November 23, 2018 It's coming along nicely Steve , keep up the good work 1 Quote Link to post Share on other sites
WINGNUT 140 Posted November 24, 2018 Share Posted November 24, 2018 @Steve (sdh2903) regards Your ignition plug, not sure you have sorted it yet? But I run a zetec in mine and have been improving the wiring tinny ignition system (hoping so anyway) if the plug is a 4 pin then White = ignition supply Brown = 12v permanent Green = fuel pump White/black = tacho signal Colours may vary I'm told on age of loom, on mine 12v permanent isn't used. I'm told this is for supplying injection ran cars for power relays etc As for the 2 brown wires I'll check my alternator later but I do know mine are independent spades to the rear of my ACR alternator, yet another job to sort at some point Scott P.s car is looking bang on mate keep up the work, another great build diary 1 Quote Link to post Share on other sites
WINGNUT 140 Posted November 24, 2018 Share Posted November 24, 2018 Just to confirm I do have 2 Brown's down to my alternator @Steve (sdh2903) 1 Quote Link to post Share on other sites
Steve (sdh2903) 3,534 Posted November 24, 2018 Author Share Posted November 24, 2018 Cheers Scott yes I have the same 4 colours. Will be a handy switched supply for the ecu if nothing else. The alternator wires will need to be chased back out and re-routed down the other side of the engine bay hopefully there's enough length on them save me extending them. Quote Link to post Share on other sites
Steve (sdh2903) 3,534 Posted November 25, 2018 Author Share Posted November 25, 2018 So I now have a bonnet that gives me a bit more room to play with regarding the inlet. Annoyingly more room as it's set my mind working again. And I know there's no inlet flange or tubes in there but there's room for these little blighters. Hmm what to do what to do...... 2 Quote Link to post Share on other sites
CosKev 1,053 Posted November 25, 2018 Share Posted November 25, 2018 I can't believe you are even pondering on what to do! You've got two sets of the bigger diameter Triumph TB's? Quote Link to post Share on other sites
Steve (sdh2903) 3,534 Posted November 25, 2018 Author Share Posted November 25, 2018 There are plus points and negatives to both options though. No I don't have the triumph ones. The bigger ones that are big enough aren't respaceable although may be that's something that danst could sort for me. The big triumphs also don't include injectors (So would retain the jag lower manifold) and they are a fairly hefty unit. The best ones that match and are respaceable are gsxr 750 (as per the ones in the pic kindly donated by @Gary Taylor - Scotland AO) or the gsxr1300 ones. But then you have to sort the issues of matching linkages between the banks etc etc Quote Link to post Share on other sites
Gary Taylor 2,144 Posted November 25, 2018 Share Posted November 25, 2018 Throttle linkage idea one cable and the two sets linked via a rose jointed linkage 5 Quote Link to post Share on other sites
Thrustyjust 3,928 Posted November 25, 2018 Share Posted November 25, 2018 20 minutes ago, Gary Taylor - Scotland AO said: Throttle linkage idea one cable and the two sets linked via a rose jointed linkage Wibble .............................. 1 Quote Link to post Share on other sites
CosKev 1,053 Posted November 25, 2018 Share Posted November 25, 2018 @Steve (sdh2903) are you using Quaife output flanges in the diff with ATB? If so how are they held in the diff? Quote Link to post Share on other sites
Chris King 5,025 Posted November 25, 2018 Share Posted November 25, 2018 Just now, CosKev said: @Steve (sdh2903) are you using Quaife output flanges in the diff with ATB? If so how are they held in the diff? Pretty sure they have circlips 1 Quote Link to post Share on other sites
Steve (sdh2903) 3,534 Posted November 25, 2018 Author Share Posted November 25, 2018 Yes I am using quaife flanges. Although I didn't fit them. I think they are just a push in fit with a snap ring. The std sierra ones are circlip 1 Quote Link to post Share on other sites
