Steve (sdh2903)
What have I done now..... V6 seiw build
On 03/09/2018 at 14:40, CosKev said:
Thought it looked quite alot smaller.
Is it baffled etc inside?
Yes it's baffled in the main oil well. There's a couple of mx5 race cars using the rocketeer kit, think in Spain or Portugal, with the rocketeer sump (and I assume an oil cooler) with no issues reported.
In other news the rebuild has finally commenced!! Nothing exciting just floor, footwell and rear panels fitted, brake lines in and master cylinders fitted. But a start none the less.
20180904_135328-2268x3024.thumb.jpg.f0cfa67d95986c9d7b62f8a1d69ecdd4.jpg120180904_162229-3024x2268.thumb.jpg.16cd78e82bbb4601e3d883a1d90181ae.jpg
I'm not fitting anything else just yet as I need to flip the chassis over and gravitex the underside once the sealant is dry and then can crack on.
  • Like 6
Share this post
Link to post
Got the underside gravitexed
Some more panelling done and fuel lines in.
knocked up a tank crash bar.
20180912_102153-2016x1512.thumb.jpg.b0dc162d501418e71411f5b3e226f3ec.jpg20180912_102601-2016x1512.thumb.jpg.804af033603001e677055c8c8c5fbe09.jpg
Diff is in. Decided to helicoil and bolt in as I've never been a fan of the studs.
I've had to refit the engine as I'd forgotten to measure up for a prop.
Tested for clearance with the standard bonnet.
Oil cap is tight!
While the welder is out I wanted to weld up the upper column section.
I bevelled the ends and welded up
You can just see the extra sleeve at the bottom of the pic. The weld was ground back then the joint was sleeved with a tube with holes drilled in. This was then seam welded and the holes plug welded and then cleaned up.
Very happy with the column and the pillow block support. No play at all.
I also took the chance to play around with exhaust routing. I'm still hopefull of being able to run the right bank under the cut out in the sump across to the left bank. I need a couple more bends and possibly a flexy. This will hopefully give a nicer sound than 2 separate sides and also keep costs down a bit as I'll only need 1 cat and 1 exhaust. I'm just struggling to find a merger that's suitable now. I need 2" dual inlets to a 2.5 or 3" outlet preferably with slip joints.
  • Like 4
Share this post
Link to post
If you wanted a little more breathing room for the oil cap, you can raise the nose cone ever so slightly, and as a result, the bonnet will also raise a little at the front.  The gap (if any) can be taken up by sponge foam...  I've had to do this when I went from Xflow to Zetec.
Progress is looking good!
Share this post
Link to post
Cheers quinten. There's about 5mm at the minute. I reckon with the side panels on and some foam inbetween I'll gain another 5mm so should be ok i think.
Share this post
Link to post
Very good call. Might be one of my winter upgrades.
Share this post
Link to post
Nice work and Looks good and those bonnet on pictures are a big help to give me an idea of clearances
are you staying with those ex manifolds as I remember you thought about going bespoke
soon be October and time to start my upgrades
Share this post
Link to post
There's around 120mm of clearance between the inlet face to the bonnet at present Gary. Maybe gain 30mm with a v8 bonnet if I can find a good red one. Am still not sure there's enough room for gsxr ITBs at present. I suspect you'd sneak In those triumph ones your using as they're a compact complete unit.
Regards the ex manifolds. I'm still not 100% on keeping them but they were cheap and I have them but there's no doubt I'll prob lose a bit of power. But looking at the oem log type that were fitted they can't be any worse. I think it will be likely I keep these to get the thing built and maybe look at better manifolds in future winters.
Share this post
Link to post
The last (hopefully) of the clean and prep is now done. I was hoping to use the cv joints however there was bits of corrosion where the grease hadn't covered. The boots were all starting to perish. So full clean, paint and rebuild required.
I had thought on first glance that the rear disks were shot too. But a quick whiz over with the wire wheel in the grinder cleaned them up a treat. Then gave all the discs a coat of vht.
The used front calipers looked perfectly serviceable but a bit grubby so they've had a spruce up aswell. I've just decided if I'm brave enough to sand off the westfield lettering or just leave alone.
  • Like 4
Share this post
Link to post
if you don't it will "bug" you going forward :westy:
Share this post
Link to post
Time has been scarce so only a wee update.
I took some bravery pills and got the dremel out.
They do look better for it. Just a little bit of touch up to do once they're fitted.
Got the pedals in.20180924_163611-2016x1512.thumb.jpg.9fcae5b4ddabc882d75de87932b890bf.jpg
Checked out the clearance for the clutch slave. I'd left a notch for clearance but don't think I'll need it.20180924_163651-1512x2016.thumb.jpg.813b69b866231bd78d2aa97d9900529a.jpg
Also I can fit the clutch rest panel from the tunnel side which is a bonus for my fat feet.
Got the propshaft made. I'd tried Bailey Morris who I've always used in the past but the guy on the phone was less than interested and was 50% more than the last prop I bought from them.
So a mate recommended Dave mac props. The guy was very helpful. Price was good and mega quick. I only ordered Thurs afternoon and it arrived lunchtime today. Looks well made too. Highly recommended.
So next steps are engine back out. Finish panelling the tunnel. And run the loom In. Now I have the prop am going to final fit the engine asap as I've got used to having the space in the garage! I can't see any real reason why it can't go in at this early stage.
I've also admitted defeat in my exhaust quest to run it out one side. It was just too tight and ran pipes next to starter and alternator which would have came with it's own problems. So it will be a conventional down the sides system. But I do have a couple ideas to incorporate a balance pipe and maybe a rear exit pipe we'll see.
  • Like 3
Share this post
Link to post
Plenty of room around slave cylinder :cool:
Is prop all new,or did you send him the gearbox end?
Share this post
Link to post
I enquired about getting an mx5 prop shortened as I had one in the loft but as it's 25 years old I had a full new one made. It wasn't worth the small saving in the end so went will an all new one.
Share this post
Link to post
Looking good Steve, maintaining your usual high standard of engineering. Intrugued to see what you end up with exhaust wise, should sound awesome!
Please keep the updates coming, around the encumberence of "earning a crust obviously".
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
