Peter (Monty)
Battery Options
Peter (Monty)
I don't want to start any fights, but what battery would people recommend? I've been thinking PC680 but it's not the cheapest.
There are a bunch of 51913-sized batteries listed here:
https://www.tayna.co.uk/51913-Motorcycle-Batteries-G83.html
The CCA ratings seem to vary a lot although I gather this is partially as different standards measure it at different temperatures, making it hard to compare like for like...
Share this post
Link to post
Thrustyjust
The S2000 needs a couple of revolutions for it to pick timing up, so although the 680 was great on my Zetec, which would fire on half a turn, I was thinking of what to change my lead acid one for and would probably go up a size on the 680, just for the cranking requirement.
Share this post
Link to post
CraigHew
Odyssey PC625 in mine.  Performs exceptionally well, not too large either.
Was about £95
Share this post
Link to post
RussH
This on my Duratec. Cheaper and lighter than a PC680.
Not sure how hard the S2K is too crank though, and my car has minimal ancillaries.
Share this post
Link to post
TableLeg
I don't know what engine you're using but the PC680 cranks my V8 with 10:1 compression no problems.
Share this post
Link to post
Thrustyjust
PC680 or equivalents the one then :d
  • Haha 1
Share this post
Link to post
Peter (Monty)
I went for the PC680. Does anyone use bolt-on or quick-release terminals? I'm not sure how to properly boot the positive side.
If you fit a kill switch, does that go on the positive or negative side? And is it possible to wire in a quick connect for a battery charger?
Share this post
Link to post
TableLeg
Hi Monty,
I made my battery cables with M6 lug ends. Battery goes direct to master switch, then from master switch to starter.
I also have a fused pair of cables direct from the battery to a 12v accessory socket. This way I can plug in my charger directly.
Edited by TableLeg
Typos
Share this post
Link to post
CraigHew
I've got my C-Tec quick connecter permanantly connected to my battery (via its 2 tails). It's cable tied down next to the battery tray.
Share this post
Link to post
43 minutes ago, Wilfman said:
That's not a lot of money to set your car on fire with..............potentially :p...............and your car it too nice to torch! :yes:
  • Haha 1
Share this post
Link to post
RussH
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
21 minutes ago, RussH said:
I wondered if it was a Lithium chemistry based battery, but looking at the link, it’s “just” an AGM.
so
too.
Share this post
Link to post
45 minutes ago, RussH said:
I'm challenging the cheap price!
  • Haha 1
Share this post
Link to post
Mole
Big Chinese company..making lead acid batteries.. I couldn't see if can be mounted flat.. they have auto vent system..
Share this post
Link to post
